S7-1200/1500 Drivers
Is the latest version of VTscada, 11.2. Siemens S7 driver compatible with the S7-1200 and S7-1500 PLCs?
The driver list pdf on the website did not specifically list those models and I was curious.
Thanks,
JP
Is the latest version of VTscada, 11.2. Siemens S7 driver compatible with the S7-1200 and S7-1500 PLCs? The driver list pdf on the website did not specifically list those models and I was curious. Thanks, JP
We have tested our built-in Siemens S7 PLC driver with S7-200, S7-300, and S7-400 Series PLCs.
However, we have customers who are successfully using this driver to also connect to S7-1200 and S7-1500 Series PLCs. (In the Siemens S7 PLC Driver configuration dialog simply select the S7-300 PLC Type on the Options tab.)
Keep in mind that Trihedral has done no testing on these devices and makes no guarantee about their reliability, performance, or supported features using this driver.
For those new to VTScada, you can see all of our integrated SCADA device drivers listed here:
https://www.trihedral.com/device-driver-list
We have tested our built-in Siemens S7 PLC driver with S7-200, S7-300, and S7-400 Series PLCs. However, we have customers who are successfully using this driver to also connect to S7-1200 and S7-1500 Series PLCs. (In the Siemens S7 PLC Driver configuration dialog simply select the S7-300 PLC Type on the Options tab.) Keep in mind that Trihedral has done no testing on these devices and makes no guarantee about their reliability, performance, or supported features using this driver. For those new to VTScada, you can see all of our integrated SCADA device drivers listed here: https://www.trihedral.com/device-driver-list
603
