Opacity of objects based on tag enable or disable
I want to control the opacity of objects on screen like if the object is linked to a tag and tag is enabled, the screen should display the object. If we disable the tag, it should disable showing the object on the screen as well. How to do it.
If you're in a tag widget for instance, then you can use:
Valid(\Root\ChildTag)
If you're in a tag widget for instance, then you can use: ```` Valid(\Root\ChildTag) ````
59
