How can Disable Automatic Deploy Changes
How can I make disable Automatic Deploy Changes in VTScada.
When I try to deploy changes it says it's not applicable because of enabling automatic deploy changes.
How can I disable this?
Where are those options to disable this?
5f10433c1c2a2
How can I make disable Automatic Deploy Changes in VTScada. When I try to deploy changes it says it's not applicable because of enabling automatic deploy changes. How can I disable this? Where are those options to disable this? ![5f10433c1c2a2](serve/attachment&path=5f10433c1c2a2)
You can disable Auto Deploy under the 'other' tab in edit properties:
5f108179af268
Hope this helps.
You can disable Auto Deploy under the 'other' tab in edit properties: ![5f108179af268](serve/attachment&path=5f108179af268) Hope this helps.
41
