Create TCP Server in VTScada
I want to create TCP Server in VTScada application.
That TCP server can listen on Defined IP & Port and that can be used to connect with TCP Client.
How can I create TCP server in VTScada?
Please share step by step guide.
I want to create TCP Server in VTScada application. That TCP server can listen on Defined IP & Port and that can be used to connect with TCP Client. How can I create TCP server in VTScada? Please share step by step guide.
TCP server is a bit vague. VTScada comes with an http (TCP based) server built in (REST interface.) Docs are on line. Then you can read information out of the historian. https://www.vtscada.com/help/Content/D_LogAndReport/D_RESTQueries.htm?TocPath=Use%20VTScada%7CLog%2C%20Note%2C%20and%20Report%7CSQL%20Queries%3A%20The%20ODBC%20Server%7C_____5
77
