Changed time zone and Historical Data Viewer is misbehaving...
I've begun using VTScadaLIGHT and I've run into some trouble. I started logging some data and I noticed after a few days that my timestamp is off. Turns out the system's clock was set for the wrong time zone.
I changed it (pacific time to eastern time) and now the Historical Data Viewer is misbehaving...for all tags. When I resume the live view, the far right side is lined up w/ the current time, but data is still being logged under a timestamp that was three hours ago. Just a long three-hour horizontal line between the two. It also doesn't update in real-time w/o toggling the pause/resume live view button or closing and reopening the trend.
How do I fix this? I've tried restarting VTScada w/o effect.
Thanks.
Hello, I've begun using VTScadaLIGHT and I've run into some trouble. I started logging some data and I noticed after a few days that my timestamp is off. Turns out the system's clock was set for the wrong time zone. I changed it (pacific time to eastern time) and now the Historical Data Viewer is misbehaving...for all tags. When I resume the live view, the far right side is lined up w/ the current time, but data is still being logged under a timestamp that was three hours ago. Just a long three-hour horizontal line between the two. It also doesn't update in real-time w/o toggling the pause/resume live view button or closing and reopening the trend. ** How do I fix this?** I've tried restarting VTScada w/o effect. Thanks.
The data should be correct moving forward.
You won't be able to get rid of that horizontal line for 3 hours (without significant effort in querying and importing historical data), since the data was being logged 3 hours off.
The data should be correct moving forward. You won't be able to get rid of that horizontal line for 3 hours (without significant effort in querying and importing historical data), since the data was being logged 3 hours off.
35
