Setting OPC Server
Dear Sir,
our client want to pool data from VTScada server,
the VTScada already have OPC server license,
they want to pool data from another computer,
is there any tutorial / guide?
we already try to read the documentation, but still not understand,
  • where we create the Opcserver tags? is it below the driver / port tags?
  • for example server and client user windows 7, whats should we configure in windows?
Dear Sir, our client want to pool data from VTScada server, the VTScada already have OPC server license, they want to pool data from another computer, is there any tutorial / guide? we already try to read the documentation, but still not understand, - where we create the Opcserver tags? is it below the driver / port tags? - for example server and client user windows 7, whats should we configure in windows?
Check out the following from the VTScada online help files:
https://www.vtscada.com/help/Content/D_Tags/Dev_OPCServerTag.htm
Note: You can press F1 in VTScada at any time to load the built-in files which will be specific to the version of VTScada you are using.
Check out the following from the VTScada online help files: https://www.vtscada.com/help/Content/D_Tags/Dev_OPCServerTag.htm Note: You can press F1 in VTScada at any time to load the built-in files which will be specific to the version of VTScada you are using.
