1. Use the big A in the Idea Studio Ribbon to add a text box.
2. Right-click to open Text Properties.
3. Open the expression editor in the top right corner (Blue and white box).
4. Enter this function and close the dialog and close the Idea Studio.
Time( Now(2), 2)
Make a new text box and use this function.
Time( Now(2), 7)
See more time formatting options here...
https://www.vtscada.com/help/Content/p_Reference/ref_TimeFormats.htm
For an example of some time formatting equations that you can use in VTScada expressions; check out this post: https://forum.trihedral.com/index.php?u=/topic/555/showing-time-data-from-tag#post-1658
Pending draft
Your previous draft for topic is pending
If you continue, your previous draft will be discarded.
Add link
Upload
With selected
deselect postsshow selected posts
Selected posts
Topic:
Selected posts:
Confirm move posts
One of the posts you selected
is the main post of the topic, moving this post
will make the oldest non-moved post of
as the main topic post
You have selected all the posts from the topic, hence after moving
will be deleted
Are you sure you want to move
post(s) from the topic
to the topic
Insufficient permissions
You do not have permission to move posts to this category.
Select a different topic
You cannot move posts to the same topic.
Please go to a different topic.
Confirm selection
Are you sure you want to check this post ?
If you click 'Yes', your selection for the topic
will be cleared
