how to use UserLogonDialog
I want to use a button to pop up the dialog box for user login. I read the manual to use UserLogonDialog, but it failed to test successfully. Can you give me a sample, thank you
edited Oct 31 '21 at 2:26 pm
The function must be called from a script and then the code must wait for the return value becoming invalid, e.g.
  WaitObj;
Init [
  { When triggered display the logon dialog }
  If Trigger Wait;
    WaitObj = SecurityManager\UserLogonDialog(Invalid, Invalid, TRUE, FALSE);
Wait [
  If !Valid(WaitObj);
    { Do Something }
The function must be called from a script and then the code must wait for the return value becoming invalid, e.g. ```` ... [ WaitObj; ] ... Init [ { When triggered display the logon dialog } If Trigger Wait; [ WaitObj = SecurityManager\UserLogonDialog(Invalid, Invalid, TRUE, FALSE); ] ] Wait [ If !Valid(WaitObj); [ { Do Something } ] ] ````
74
