Rotate is Invalid
Rotate(Normalize(0, 0, 360),0,360,Point(0, 0, Invalid, Invalid))
Why the return value is Invalid?
Rotate(Normalize(0, 0, 360),0,360,Point(0, 0, Invalid, Invalid)) Why the return value is Invalid?
Works for me.
Normally you would pass a variable into the first parameter of the Normalize() call.
Note that the output is a "rotation value", which can't be observed directly in the Source Debugger, only it's validity and the value is normally passed into another graphic statement.
Works for me. Normally you would pass a variable into the first parameter of the `Normalize()` call. Note that the output is a "rotation value", which can't be observed directly in the Source Debugger, only it's validity and the value is normally passed into another graphic statement.
30
