GE series 90 driver virtual PLC
I want to simulate the environment of PLC and HMI communication on VTScadaLight using GE Fanuc Series 90 driver so that I can run a virtual PLC using port 18245 and HMI on the same computer. Can anyone please tell me whether it is possible and if it is then how should I work it out.
Thank you.
Hello, I want to simulate the environment of PLC and HMI communication on VTScadaLight using GE Fanuc Series 90 driver so that I can run a virtual PLC using port 18245 and HMI on the same computer. Can anyone please tell me whether it is possible and if it is then how should I work it out. Thank you.
Sure, should be possible, I use simulated PLCs a lot.
Generally just run the PLC simulator and configure VTScada to connect to it, either using the local machine name or one of the loopback addresses 127.0.0.1 or ::1.
Sure, should be possible, I use simulated PLCs a lot. Generally just run the PLC simulator and configure VTScada to connect to it, either using the local machine name or one of the loopback addresses `127.0.0.1` or `::1`.
46
