Can VTScada let the PLC know if a particular alarm is active?
I have a number of analog I/O & calculation tags configured with advanced alarms.
I'd like some of these alarms to write to the PLC, setting a bit when they are active then resetting that bit when they are inactive.
Can this be configured? If so, how?
I have a number of analog I/O & calculation tags configured with advanced alarms. I'd like some of these alarms to write to the PLC, setting a bit when they are active then resetting that bit when they are inactive. Can this be configured? If so, how?
There are a number of ways to do this, one simple way would be to made an IO and Calc tag configured as a digital calculation. Then you can set the calculation to an expression similar to:
[AlarmTagName] == 1 ? 1 : 0
Set the address to your PLC address you wish to write to a 1 or 0 depending on the alarm condition.
There are a number of ways to do this, one simple way would be to made an IO and Calc tag configured as a digital calculation. Then you can set the calculation to an expression similar to: [AlarmTagName] == 1 ? 1 : 0 Set the address to your PLC address you wish to write to a 1 or 0 depending on the alarm condition.
Thank you so much. This is going to save me so much work.
Not exactly sure how VTScada name their alarm tag names but I think I can figure this out. If it's not explained in the help I'll reply with a follow up question.
Thank you so much. This is going to save me so much work. Not exactly sure how VTScada name their alarm tag names but I think I can figure this out. If it's not explained in the help I'll reply with a follow up question.
edited Feb 8 '22 at 7:50 pm
So it turns out I don't have actual alarm tags. I have an analog I/O & calculation tags with advanced alarms configured from it's tab.
You mentioned there is a number of ways this can be done & I see you work for VTScada. Could we chat over the phone about this? Perhaps one of the other ways that came to mind for you be a better when I apply it.
So it turns out I don't have actual alarm tags. I have an analog I/O & calculation tags with advanced alarms configured from it's tab. You mentioned there is a number of ways this can be done & I see you work for VTScada. Could we chat over the phone about this? Perhaps one of the other ways that came to mind for you be a better when I apply it.
No need Dave, I found a way to do this that works well with what I've built.
I'm glad you figured out a way to make this work in your system.
Learn about using tag values in expressions here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagValues.htm
Note that you can also use tag properties and not just their values, these options are not well documented in the help files but for example [TagName]\Description would return the tag description. There are ways to get all of the available properties of each tag type but you typically have to create a custom tag type to easily see those options. I can't remember the alarm references but they are something like [Tag Name]\HighAlarmActive. IF I get a chance tonight, I'll update this will a list of the available properties for the I/O and Calc tag in VTScada 12.0.50
I'm glad you figured out a way to make this work in your system. Learn about using tag values in expressions here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagValues.htm Note that you can also use tag properties and not just their values, these options are not well documented in the help files but for example [TagName]\Description would return the tag description. There are ways to get all of the available properties of each tag type but you typically have to create a custom tag type to easily see those options. I can't remember the alarm references but they are something like [Tag Name]\HighAlarmActive. IF I get a chance tonight, I'll update this will a list of the available properties for the I/O and Calc tag in VTScada 12.0.50
edited Feb 10 '22 at 1:34 am
Yep, that's exactly what I did. My analog I/O & calculations tag's called reading.
The syntax is [reading]\HighAlarmActive.
No need to reply here with a list of avilable properties but if that could be added to the help this would be great. I had to use the source debugger to get the property names but I found that tool hard to use.
Yep, that's exactly what I did. My analog I/O & calculations tag's called reading. The syntax is [reading]\HighAlarmActive. No need to reply here with a list of avilable properties but if that could be added to the help this would be great. I had to use the source debugger to get the property names but I found that tool hard to use.
Here are some commonly used properties for the I/O and Calc Tags
[TagName]\Name
[TagName]\HighHighAlarmActive
[TagName]\HighAlarmActive
[TagName]\LowAlarmActive
[TagName]\LowLowAlarmActive
[TagName]\AlarmActive
[TagName]\DigitalAlarmActive
You can learn to find all of the properties for any tag by reading the help files here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagProperties.htm?tocpath=Scripting%7CExpressions%7C_____8
Here are some commonly used properties for the I/O and Calc Tags [TagName]\Name [TagName]\Description [TagName]\HighHighAlarmActive [TagName]\HighAlarmActive [TagName]\LowAlarmActive [TagName]\LowLowAlarmActive [TagName]\AlarmActive [TagName]\DigitalAlarmActive You can learn to find all of the properties for any tag by reading the help files here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagProperties.htm?tocpath=Scripting%7CExpressions%7C_____8
edited Feb 14 '22 at 6:10 pm
Does anyone else get gibberish when they reference the equipment type or description properties in an expression?
63dc3626d058a
For some properties like Name, I get the value I expect, and others return strange values.
Does anyone else get gibberish when they reference the equipment type or description properties in an expression? ![63dc3626d058a](serve/attachment&path=63dc3626d058a) For some properties like Name, I get the value I expect, and others return strange values.
Since VTScada 12, when multi language support was introduced, text properties refer to the Phrase Key rather than the phrase itself. You'll need to use a call such as \GetPhrase(..\Description) to get the string you are looking for.
You can learn more about this and view some examples here: https://www.vtscada.com/help/Content/Pro_Functions/GetPhrase.htm
Since VTScada 12, when multi language support was introduced, text properties refer to the Phrase Key rather than the phrase itself. You'll need to use a call such as \GetPhrase(..\Description) to get the string you are looking for. You can learn more about this and view some examples here: https://www.vtscada.com/help/Content/Pro_Functions/GetPhrase.htm
10
