Read IP address of the Module
Hello all,
I want to read the Module IP address and show that in screen under each Module Image. All I got is TCPIP port's status value but not IP address.
How can I read the IP address from the TCP port and show that in the screen for the concerned module.
Note: Do not want to add manually. It will be customizable and may be changed in future. So as per change should also reflect in the screen of the updated/changed IP address.**
Hello all, I want to read the Module IP address and show that in screen under each Module Image. All I got is TCPIP port's status value but not IP address. How can I read the IP address from the TCP port and show that in the screen for the concerned module. Note: Do not want to add manually. It will be customizable and may be changed in future. So as per change should also reflect in the screen of the updated/changed IP address.****
Great Question and the answer is also really simple. Just create an expression either in a text box on a page or in an IO tag in String Calc mode with your tag name backslash Address.
Here is an example of a tag using the absolute tag name which would be suitable for drawing on an application page: [<Liftstations\MC_LS_N_01\TCPPort>]\Address
You can learn to find all of the properties for any tag by reading the help files here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagProperties.htm?tocpath=Scripting%7CExpressions%7C_____8
Great Question and the answer is also really simple. Just create an expression either in a text box on a page or in an IO tag in String Calc mode with your tag name backslash Address. Here is an example of a tag using the absolute tag name which would be suitable for drawing on an application page: [&lt;Liftstations\MC_LS_N_01\TCPPort&gt;]\Address You can learn to find all of the properties for any tag by reading the help files here: https://www.vtscada.com/help/Content/Scripting/Expressions/UseTagProperties.htm?tocpath=Scripting%7CExpressions%7C_____8
