MODBUS tcp/ip .... something escapes me...
Good morning,
I just installed this wonderful SCADA, and following the help, I can not make a connection using MODBUS TCP/IP... something I am not doing well.
The modbus tcp/ip communication I do perfectly from other software, and I read and write in all directions well.
The data I have on the other soft:
LAPTOP IP: 192.168.82.200
SLAVE MODBUS: 192.168.82.1
PORT: 502
I think that the problem I have, or that I do not select well the type of MODBUS in VTSCADA...
TAG BROWSER attachment, as I have it initially.
Thank you and a greeting!
Javier621df6066a5e3
621df606d6cef
Good morning, I just installed this wonderful SCADA, and following the help, I can not make a connection using MODBUS TCP/IP... something I am not doing well. The modbus tcp/ip communication I do perfectly from other software, and I read and write in all directions well. The data I have on the other soft: LAPTOP IP: 192.168.82.200 SLAVE MODBUS: 192.168.82.1 PORT: 502 I think that the problem I have, or that I do not select well the type of MODBUS in VTSCADA... TAG BROWSER attachment, as I have it initially. Thank you and a greeting! Javier![621df6066a5e3](serve/attachment&path=621df6066a5e3) ![621df606d6cef](serve/attachment&path=621df606d6cef)
63
