ClearSCADA migration to VTScada
I am dealing with a few sites that are split between ClearScada and VTScada. The goal is to have all of the sites in VTScada and I would like to know if there is a possible process in place to migrate the files and tags from ClearScada into VTScada? Or if there is another process (besides manually making new applications in VTScada for the old ClearScada sites).
Thanks!
I am dealing with a few sites that are split between ClearScada and VTScada. The goal is to have all of the sites in VTScada and I would like to know if there is a possible process in place to migrate the files and tags from ClearScada into VTScada? Or if there is another process (besides manually making new applications in VTScada for the old ClearScada sites). Thanks!
Please reach out to one of the technical sales team at Trihedral for some help with your conversion. ( https://www.vtscada.com/contact-us/ )
VTScada can import your tags - This is accomplished by exporting and importing an excel tag database (Sometimes, you can just send Trihedral the tags you have as an export to xlsx or csv and they can run a conversion tool for you to make a file to import.
VTScada can also import your history - You can see that process by watching the following video: https://youtu.be/NN_YGMpKxKU
VTScada can import your custom graphics - This isn't a direct import of your pages, but you can add any special graphics to an application and easily build you pages to look like your old system. That said, when moving to VTScada, it is often a good time to update your graphics to something more modern and built for higher resolution displays. You may also want to implement some of the ISA101 guidelines as well. VTScada has built-in widgets to help with that.
Please reach out to one of the technical sales team at Trihedral for some help with your conversion. ( https://www.vtscada.com/contact-us/ ) **VTScada can import your tags** - This is accomplished by exporting and importing an excel tag database (Sometimes, you can just send Trihedral the tags you have as an export to xlsx or csv and they can run a conversion tool for you to make a file to import. **VTScada can also import your history** - You can see that process by watching the following video: https://youtu.be/NN_YGMpKxKU **VTScada can import your custom graphics** - This isn't a direct import of your pages, but you can add any special graphics to an application and easily build you pages to look like your old system. That said, when moving to VTScada, it is often a good time to update your graphics to something more modern and built for higher resolution displays. You may also want to implement some of the ISA101 guidelines as well. VTScada has built-in widgets to help with that.
