SQLDataQueryDriver Connecting to a custom database
SQL
Please give advice on setting up the SQLDataQueryDriver. Table to store your data. MSAccess, The driver is configured in ODBS. When connected, it gives status 102. VT SCADA Light!
I also ask you to explain how the result of the SQL! is addressed (explain using my example of the SQL query)
62615b6dcf12d
Thanks
Please give advice on setting up the SQLDataQueryDriver. Table to store your data. MSAccess, The driver is configured in ODBS. When connected, it gives status 102. VT SCADA Light! I also ask you to explain how the result of the SQL! is addressed (explain using my example of the SQL query) ![62615b6dcf12d](serve/attachment&path=62615b6dcf12d) Thanks
31
