application from workstation with loopback address
When configuring an application and choosing "from a workstation" (via advanced), if I enter a loopback address (eg. 127.0.0.2), or a hostname (via hosts file) that also points to a loopback address, it seems vtscada does not make any attempt to connect to RPC to this address. The use case here is a local proxy server connecting the TCP connection (via port 5780) to a remote VTScada server. Is this known behavior and if so, is there anyway to disable it?
thanks, mike.
When configuring an application and choosing "from a workstation" (via advanced), if I enter a loopback address (eg. 127.0.0.2), or a hostname (via hosts file) that also points to a loopback address, it seems vtscada does not make any attempt to connect to RPC to this address. The use case here is a local proxy server connecting the TCP connection (via port 5780) to a remote VTScada server. Is this known behavior and if so, is there anyway to disable it? thanks, mike.
99
