Historian and JSON
How do you integrate JSON history into the a JSON tag...the video and examples, don't dig much into it.
thanks
Hello, How do you integrate JSON history into the a JSON tag...the video and examples, don't dig much into it. thanks
Once you connect your I/O tags to the JSON driver, all the history will be recorded per the tag configuration. This is the same as the I/O tags within any of the drivers.
Does that make sense?
Once you connect your I/O tags to the JSON driver, all the history will be recorded per the tag configuration. This is the same as the I/O tags within any of the drivers. Does that make sense?
For the live Json data, that is true. I have a seperate URL for more refined history data, which I wish to backfill into the original data.
URL 1 .. hourly data
URL 2 .. minute by minute data, updated on the hour (not live). with an array of values and timestamps.
I suppose I could just import 60 data points every hour, but how would I go about setting up the tags for that.
thanks
For the live Json data, that is true. I have a seperate URL for more refined history data, which I wish to backfill into the original data. URL 1 .. hourly data URL 2 .. minute by minute data, updated on the hour (not live). with an array of values and timestamps. I suppose I could just import 60 data points every hour, but how would I go about setting up the tags for that. thanks
For that, you will need to do some custom work however the bulk of that is laid out for you in the help files here: https://www.vtscada.com/help/Content/D_Tags/Dev_JSONDriver.htm
See the processor section and you will find nearly everything you need in the custom processor link.
For that, you will need to do some custom work however the bulk of that is laid out for you in the help files here: https://www.vtscada.com/help/Content/D_Tags/Dev_JSONDriver.htm See the processor section and you will find nearly everything you need in the custom processor link.
I followed the instructions and wrote the JSON Processor, I just don't see how I bring that to work with a tag. Do you have a complete example. It seems I have a lot of pieces, but I am just missing a simple thing to bring it all together. Baring you having a complete example, I can send my test changeset for you to look at.
thanks
I followed the instructions and wrote the JSON Processor, I just don't see how I bring that to work with a tag. Do you have a complete example. It seems I have a lot of pieces, but I am just missing a simple thing to bring it all together. Baring you having a complete example, I can send my test changeset for you to look at. thanks
If you could show an example of using historical Json data into the tag, or something similar that would be great.
From the Example Code in VTScada Help.
 NewData = Dictionary();
NewData["J1"] = TimeValuePair(Data.DataValues.T1, Data.DataValues.V1);
NewData["J2"] = TimeValuePair(Data.DataValues.T2, Data.DataValues.V2);
NewData["J3"] = TimeValuePair(Data.DataValues.T3, Data.DataValues.V3);
NewData["History"] = TimeValuePair(New(3), New(3));
NewData["History"].Timestamp[0] = Data.DataValues.T1;
NewData["History"].Timestamp[1] = Data.DataValues.T2;
NewData["History"].Timestamp[2] = Data.DataValues.T3;
NewData["History"].Value[0]     = Data.DataValues.V1;
NewData["History"].Value[1]     = Data.DataValues.V2;
NewData["History"].Value[2]     = Data.DataValues.V3;
NewData["UniqueID"]             = UniqueID;
NewData["Timestamp"]            = "Not a timestamp";
Return(NewData);
If this was An Analog status tag, would I put J1, in the current value, and History[0] in the tag?
From the Example Code in VTScada Help. NewData = Dictionary(); NewData["J1"] = TimeValuePair(Data.DataValues.T1, Data.DataValues.V1); NewData["J2"] = TimeValuePair(Data.DataValues.T2, Data.DataValues.V2); NewData["J3"] = TimeValuePair(Data.DataValues.T3, Data.DataValues.V3); NewData["History"] = TimeValuePair(New(3), New(3)); NewData["History"].Timestamp[0] = Data.DataValues.T1; NewData["History"].Timestamp[1] = Data.DataValues.T2; NewData["History"].Timestamp[2] = Data.DataValues.T3; NewData["History"].Value[0] = Data.DataValues.V1; NewData["History"].Value[1] = Data.DataValues.V2; NewData["History"].Value[2] = Data.DataValues.V3; NewData["UniqueID"] = UniqueID; NewData["Timestamp"] = "Not a timestamp"; Return(NewData); If this was An Analog status tag, would I put J1, in the current value, and History[0] in the tag?
94
6
