VTScada Lite install issue
Good Afternoon,
I was trying to install VTScada lite earlier today, and ran into the following message "The program can't start because api-ms-win-downlevel-kernel32-I2-1-0.dll is missing from your computer, try reinstalling the program to fix this problem".
I made sure the computer was current on its windows updates, and tried to reinstall, and I ran into the same issue. The computer is running Windows 7 Pro 32 bit. Has anyone run into this issue before, or know how to fix it?
Good Afternoon, I was trying to install VTScada lite earlier today, and ran into the following message "The program can't start because api-ms-win-downlevel-kernel32-I2-1-0.dll is missing from your computer, try reinstalling the program to fix this problem". I made sure the computer was current on its windows updates, and tried to reinstall, and I ran into the same issue. The computer is running Windows 7 Pro 32 bit. Has anyone run into this issue before, or know how to fix it?
A quick search shows this as a Windows error after installing software with certain dependencies. Luckily the solution may be a simple fix.
That said, the current VTScada installer is not listed as compatible with Windows 7 so it may be that this library is not included with Windows 7.
VTScada Requirments: https://www.vtscada.com/scada-system-requirements/
Your .dll Issue on Stack Overflow: https://stackoverflow.com/questions/65858706/the-program-cant-start-because-api-ms-win-downlevel-kernel32-l2-1-0-dll-is-miss
A quick search shows this as a Windows error after installing software with certain dependencies. Luckily the solution may be a simple fix. That said, the current VTScada installer is not listed as compatible with Windows 7 so it may be that this library is not included with Windows 7. VTScada Requirments: https://www.vtscada.com/scada-system-requirements/ Your .dll Issue on Stack Overflow: https://stackoverflow.com/questions/65858706/the-program-cant-start-because-api-ms-win-downlevel-kernel32-l2-1-0-dll-is-miss
edited Aug 19 '22 at 3:27 pm
99
