I/O Calculation Expressions
Hi all,
Is it possible to implement "IF" "ELSEIF" operator functions at the I/O tag expression level?
I would normally write my expression as...
IF ([06. Profile Section] == 6) THEN ;
((3.145 *([08. Width]  / 2) *([08. Width]  / 2) * ([09. Length]) / 1000000000) * 100) ;
ELSEIF ;
([06. Profile Section] == 7) THEN ;
(((3.145 *([08. Width]  / 2) *([08. Width]  / 2) / 2) * ([09. Length]) / 1000000000) * 100) ;
ENDIF;
If not does anybody know how i could implement this function?
Thanks in advance,
Joe.
Hi all, Is it possible to implement "IF" "ELSEIF" operator functions at the I/O tag expression level? I would normally write my expression as... ```` IF ([06. Profile Section] == 6) THEN ; ((3.145 *([08. Width] / 2) *([08. Width] / 2) * ([09. Length]) / 1000000000) * 100) ; ELSEIF ; ([06. Profile Section] == 7) THEN ; (((3.145 *([08. Width] / 2) *([08. Width] / 2) / 2) * ([09. Length]) / 1000000000) * 100) ; ENDIF; ```` If not does anybody know how i could implement this function? Thanks in advance, Joe.
edited Jan 16 at 12:23 pm
You can do this using nested IfElse() statements. You can use the built in function helper (click the f(x) button when working on an expression) to use built in methods for If Than or If Else statements. (https://www.vtscada.com/help/Content/Scripting/Expressions/FunctionSelectionDlg.htm)
You can also use ternary operators to do the same thing though they can be confusting when trying to do an If Else statment.
To return the current value when no action should be taken, you should be able to use \value in your expression.
You can do this using nested IfElse() statements. You can use the built in function helper (click the f(x) button when working on an expression) to use built in methods for If Than or If Else statements. (https://www.vtscada.com/help/Content/Scripting/Expressions/FunctionSelectionDlg.htm) You can also use ternary operators to do the same thing though they can be confusting when trying to do an If Else statment. To return the current value when no action should be taken, you should be able to use \value in your expression.
Thank you for your response Dave...
I managed to complete my task by using the 'Ternary Operator (IfElse)'.
Expression example below:
((( [07. Height] 3.0 2.0) + (([08. Width] - 3.0) 3.0 2.0)) / ( [07. Height] [08. Width])) + ((([08. Width] - 6.0) ( [07. Height] - 3.0) 2.0 40.0 / (([08. Width] [07. Height]))) / [09. Length])
((( [07. Height]
6.0 2.0) + (([08. Width] - 6.0) 3.0 2.0)) / ( [07. Height] [08. Width])) + ((([08. Width] - 6.0) ( [07. Height] - 6.0) 2.0 40.0 / (([08. Width] [07. Height]))) / [09. Length])
Thanks again smile
Thank you for your response Dave... I managed to complete my task by using the 'Ternary Operator (IfElse)'. Expression example below: ([06. Profile Section] == 6) ? ((( [07. Height] * 3.0 * 2.0) + (([08. Width] - 3.0) * 3.0 * 2.0)) / ( [07. Height] * [08. Width])) + ((([08. Width] - 6.0) * ( [07. Height] - 3.0) * 2.0 * 40.0 / (([08. Width] * [07. Height]))) / [09. Length]) : ([06. Profile Section] == 7) ? ((( [07. Height] * 6.0 * 2.0) + (([08. Width] - 6.0) * 3.0 * 2.0)) / ( [07. Height] * [08. Width])) + ((([08. Width] - 6.0) * ( [07. Height] - 6.0) * 2.0 * 40.0 / (([08. Width] * [07. Height]))) / [09. Length]) : 0 Thanks again :)
114
