How to reset a widget to its original size
Is there a way to reset an instance of a widget to its original size?
You can use CTRL-Z to undo the changes in Idea Studio.
If the Idea Studio has been closed several times, you can use the Version Log to revert to a previous version or to reverse a specific change.
You can use CTRL-Z to undo the changes in Idea Studio. If the Idea Studio has been closed several times, you can use the Version Log to revert to a previous version or to reverse a specific change.
What if you noticed somebody stretched some objects and you want to set them back to their original dimensions i.e. the dimensions when they are originally dragged on to the screen?
56
