Separating my Application
Here is my situation:
My current application has both my sewer lift stations and water towers in one application.
My water plant operators need to see only the water towers and hear alarms for them. But my sewer lift stations create an almost continuous stream of alarms. This had led them to mute the entire system.
Question:
Is there a simple way to turn of alarm sounds for my sewer lift stations while keeping the water tower sounds on?
OR
Can I copy only the Water tower tags and create a new application with only them? If so, how?
Thanks
Here is my situation: My current application has both my sewer lift stations and water towers in one application. My water plant operators need to see only the water towers and hear alarms for them. But my sewer lift stations create an almost continuous stream of alarms. This had led them to mute the entire system. Question: Is there a simple way to turn of alarm sounds for my sewer lift stations while keeping the water tower sounds on? OR Can I copy only the Water tower tags and create a new application with only them? If so, how? Thanks
You might also consider Realm-Area Filtering. It was designed for that situation.
Realm Area Filtering
You might also consider Realm-Area Filtering. It was designed for that situation. [Realm Area Filtering](https://www.trihedral.com/help/Content/D_Customize/Dev_RealmAreaFiltering.htm)
18
