Symbolic Addressing
I have a S7-1516F-3 and I have a question about tags.
I have a PLC with a lot of data blocks collecting the production counts and information. They PLC is connected to an HMI using symbolic addressing instead of absolute addressing. How can I access these tags?
Thank You!
Hello, I have a S7-1516F-3 and I have a question about tags. I have a PLC with a lot of data blocks collecting the production counts and information. They PLC is connected to an HMI using symbolic addressing instead of absolute addressing. How can I access these tags? Thank You!
Kepware has a Siemens Plus driver which supports symbolic addresses which could then be read with OPC. I imagine it is close to $3k without redundancy though.
Otherwise you will have to move or map your tags to datablocks and addresses which can be addressed by the VTScada driver.
Kepware has a Siemens Plus driver which supports symbolic addresses which could then be read with OPC. I imagine it is close to $3k without redundancy though. Otherwise you will have to move or map your tags to datablocks and addresses which can be addressed by the VTScada driver.
edited May 21 '19 at 5:54 pm
I believe you can open your PLC software and look at 'Symbol Editor' window to get a cross reference of each address.
Michael is right.
I have TIA Portal so there is no 'Symbol Editor', TIA supports symbolic addresses which have no link to global memory.
I am going to have to take and map all those symbolic tags into a datablock so I can get the DB.DBX* for example.
This is also the same with Allen Bradley Control Logix. They also use Symbolic Tags not linked to a physical address.
Michael is right. I have TIA Portal so there is no 'Symbol Editor', TIA supports symbolic addresses which have no link to global memory. I am going to have to take and map all those symbolic tags into a datablock so I can get the DB**.DBX*** for example. This is also the same with Allen Bradley Control Logix. They also use Symbolic Tags not linked to a physical address.
Hey Brandon, I'm not sure if there is a more efficient way for you to do this currently. We do support symbolic addressing on the AB PLC's using our CIP driver however this driver is AB specific (Currently).
6
