Locking out Windows
Here is a question I fielded recently:
"How can we prevent SCADA operators from accessing the Windows® Operation System of a PC running a VTScada application?"
Here is a question I fielded recently: "How can we prevent SCADA operators from accessing the Windows® Operation System of a PC running a VTScada application?"
edited Mar 13 '17 at 5:52 pm
Answer:
This is a two-part process:
1) Disable the VTScada Applications Manager (VAM) and lock the application's Display Manager in full screen.
From the VTScada Help System:
https://www.trihedral.com/help/Content/D_Customize/Dev_HideTheVam.htm?Highlight=hide%20VAM
https://www.trihedral.com/help/Content/p_Properties/DispMgrFullScreen.htm?Highlight=fullscreen
2) Disabling access to Windows (e.g., disabling the Windows button) is done outside of VTScada using Windows Administration Settings. This needs to be done by a Windows Administrator using Group Policies for Active Directory. This works differently on different OS versions.
Answer: This is a two-part process: 1) Disable the VTScada Applications Manager (VAM) and lock the application's Display Manager in full screen. From the VTScada Help System: https://www.trihedral.com/help/Content/D_Customize/Dev_HideTheVam.htm?Highlight=hide%20VAM https://www.trihedral.com/help/Content/p_Properties/DispMgrFullScreen.htm?Highlight=fullscreen 2) Disabling access to Windows (e.g., disabling the Windows button) is done outside of VTScada using Windows Administration Settings. This needs to be done by a Windows Administrator using Group Policies for Active Directory. This works differently on different OS versions.
104
