Pre scaled analog values
So the system I’m currently working on is already providing me scaled data coming out of the flow computer. This is also in conjunction to the scaling of the raw data at the PLC level for my other analog instruments.
What is the best way to make sure I’m setting up my analog status tags properly so I’m getting the right historical data recording and displaying my data properly?
So the system I’m currently working on is already providing me scaled data coming out of the flow computer. This is also in conjunction to the scaling of the raw data at the PLC level for my other analog instruments. What is the best way to make sure I’m setting up my analog status tags properly so I’m getting the right historical data recording and displaying my data properly?
If your data is already scaled, be sure to understand the data type you are looking for (Probably a float) and include that as a suffix on your I/O addresses. More on that here: https://www.vtscada.com/help/Content/D_Tags/Dev_DataSuffixesForTagIO.htm
As for scaling, just set your unscaled values to be the range of your data and your scaled values to be the same so they are 1:1 scaling. ie: Temperature Probe may be:
Unscaled Min: -40
Unscaled Max: 120
Scaled Min: -40
Scaled Max: 120
Your I/O address might look something like 40001/Float
If your data is already scaled, be sure to understand the data type you are looking for (Probably a float) and include that as a suffix on your I/O addresses. More on that here: https://www.vtscada.com/help/Content/D_Tags/Dev_DataSuffixesForTagIO.htm As for scaling, just set your unscaled values to be the range of your data and your scaled values to be the same so they are 1:1 scaling. ie: Temperature Probe may be: Unscaled Min: -40 Unscaled Max: 120 Scaled Min: -40 Scaled Max: 120 Your I/O address might look something like 40001/Float
