Adding .00 to a text
I have noticed that if I am using a text box that I am unable to type ".00" to the end of a number, really any length of that .0, .000, etc. If I type it in the program automatically removes it.
It is a small thing but it creates uniform numbers when I have to list of a few of them and the rest have single or double decimal places.
If there is a way to turn that function off?
I have noticed that if I am using a text box that I am unable to type ".00" to the end of a number, really any length of that .0, .000, etc. If I type it in the program automatically removes it. It is a small thing but it creates uniform numbers when I have to list of a few of them and the rest have single or double decimal places. If there is a way to turn that function off?
Look for this in the display tab of the I/O can calc tag. You can select the number of digits after the decimal to display. Note that this is only true for Analog (or non-discrete values).628f7822a6cfb
Look for this in the display tab of the I/O can calc tag. You can select the number of digits after the decimal to display. Note that this is only true for Analog (or non-discrete values).![628f7822a6cfb](serve/attachment&path=628f7822a6cfb)
edited May 26 '22 at 1:52 pm
If I am not linking this to a Tag is there a way? or is a Tag the only way?
The information I need to display is not live data or anything it is just groups of information that will remain static.
Just don't want to create a bunch of random Tags if I don't have to.
Thanks.
If I am not linking this to a Tag is there a way? or is a Tag the only way? The information I need to display is not live data or anything it is just groups of information that will remain static. Just don't want to create a bunch of random Tags if I don't have to. Thanks.
40
