This is a question that comes up more and more so our own Dave Spencer created this quick and easy video tutorial.
This video was created for VTScada version 11.2 in 2016-10.
https://www.youtube.com/edit?o=U&video_id=Ljc9DvsrHms
Instructions can also be found in the VTScada Help System.
https://www.trihedral.com/help/Content/D_DrawAndEdit/D_MultipleMonitors.htm?Highlight=multi%2
Is the latest version of VTscada, 11.2. Siemens S7 driver compatible with the S7-1200 and S7-1500 PLCs?
The driver list pdf on the website did not specifically list those models and I was curious.
Thanks,
JP
From a customer: Can multi-monitor layouts be configured separately for different users?
From a customer: How easy is it to find specific tag types when creating tags?
Is historical data logging enabled by default?
Question from a customer: I wanted to double check on this configuration for the type of application that the software will be placed into.
The City will have a VTScada installation at their WWTP, and the WTP. The sites are about 2 miles apart and will only be connected through the Internet. We were planning to have two separate applications installed at each site, but allow the WTP staff t
Can web pages be integrated similar to an HTML IFRAME?
Can you acknowledge alarms from each client or only on server?
If an application is developed on VTScadaLIGHT and we need to develop more I/O than 50 could we run it on the paid version directly and add more I/O?
We have discussed running VTScadaLIGHT with alternate devices, not standard computer/server, like a NUC devise. What say you?
What I/O board or device are you using with VTScadaLIGHT? I need a low cost analog and digital in with digital out. Also, what PC are you using with the I/O?
Thank you,
Brian
What is the lowest cost computer you have successfully run VTScadaLIGHT on and what model PC is it?
Thank you,
Brian
Question - How does the new Activation affect my SI developer key? I currently have a few different versions of VTScada installed on my computer for use in development with different customers. I assume this won’t affect versions before 11.2.25, but what about going forward? Will I be able to install multiple versions of VTScada after 11.2.25? I like to work on their applications in the ver
