579
2.03k
30
163
We would like to clarify the following points related to VTScada historian storage and report export.
1) VTScada Historian Storage on NAS
We would like to confirm whether VTScada historical/tag data can be stored on a NAS (Network Attached Storage).
From VTScada documentation, we found that the Storage Location can be changed, but there is also a note stating:
“In general, d
62
sparky posted May 12 at 5:30 pm
I am looking for a way to for a user to logoff one workstation when they login to another. I am getting push back on login times being too short and the powers that be insisting on long times (4 hours or more) before they are automatically logged off. However, I've discovered that they are now either sharing one individual's login, or that person is logging in everywhere and leaving.
Either
66
VTScada alarm notifications and are now getting SendMail Error [9]: Server does not support AUTH when sending through smtp.gmail.com.
Setup:
VTScada latest version, Windows 10
SMTP server: smtp.gmail.com, port 587
Transport layer security: "Use TLS if available"
Gmail has 2-Step Verification on, using app password
POP3 incoming side works fine with the same credentials
What
120
vinicius posted Mar 24 at 8:28 pm
Hello, I'm having a problem!
I created a username and password for my project in VTScada, but I wasn't careful and must have made a mistake, and now I simply can't access anything!!!
Can you help me reset my login and password so I don't have to redo my entire project?
Thank you in advance to everyone who is interested in helping!
recent by Dave - VTScada  ·  Apr 7 at 7:05 pm
110
I would like some help from you. I need to export an analog tag to an Excel (xls) report, but when I export it via the report, the tag exports the decimal places using periods (.). I need it to export with colons (,). Is it possible to make this change? Thank you.
recent by TomE  ·  Mar 29 at 1:24 pm
123
I've looked and tested and seem to be missing what seems to be a simple concept. I'm also trying to stay away from scripting, even though I know I've found examples of doing what I need there.
I'd like to have a tag, using expressions or a special tag that I might have missed, to update based on another tag getting its value updated. I've used a trigger tag and have gotten close, but I seem
recent by cardsfan  ·  Mar 14 at 3:26 am
518
At our treatment plant we have 5 Schneider Electric Trio JR Radios. We recently had an issue with communications, but got the issue resolved. I am wanting to implement a few things on VTScada to give our operators a graphic should there ever be any kind of problems with a drop of plant wide communications. My only concern is that I do not have much experience when setting up or configuring the SN
recent by beno  ·  Mar 2 at 3:28 pm
91
I am testing Driver Multiplexer with two Kepware OPC UA servers.
Q1> When failover switching to secondary driver successfully, data updates can see in values.
But the issue is
Historian logging still considers to log or not depending on deadband value of another driver IO tag. I noticed this when I found the data is not updated in historian. How should i fix it? I want to get new
293
I am currently involved in deployment a distributed system, with a highly restrictive radio link which I am not allowed to send VTScada data across.
Modbus communications are in place for this project.
So I have:
CentralVT and CentralPLC at the central office. CentralVT talks only to CentralPLC, which servers as a data concentrator for all remote sites.
Site1VT and Site1PLC. Site1
125
jemelton posted Feb 4 at 4:16 pm
Does anyone know if Trihedral has, or plans on producing a momentary switch that actually looks like a toggle switch instead of a plain button?
We know about the momentary button and it functions the way it is supposed to function, but for aesthetic continuity we would like to have a toggle switch that is momentary.
261
Good morning,
I currently work from an established VTS application that is our treatment plant and liftstations application. I've created a "training environment application" within VAM. I was wanting to export a created tag type, but during export to "training environment" I got a failed message mentioning that it failed due to GUID differences between the original application and training
95
I downloaded VTSCADA light to create a usecase demo for about 50 tags in one shed. However, after downloading the application and on opening it - I am unable to see any options for accessing the Application Manager.
How do I access the application manager in VTSCADA Light?
Are there specific tutorials/documentation to navigate the Light version?
215
Have a new issue where most people with iPhone's cannot load a Anywhere URL. It works on all desktops and Android devices however most times when on iPhone it will not load.
VTScada was upgraded to latest version, same issue. Can't seem to find any discussions of others reporting this. Just looking to see if anywhere here has seen this.
The server logs this Windows Event when it happens.
69695add3766b
recent by b.kosty  ·  Jan 16 at 4:27 pm
220
The report tag has its "email settings" where you can manually add or remove recipients of that report.
I'd like to offer more of a self-serve option where someone can enter their email on a page/popup which would then inject an updated recipient list into the report tag or script.
Parameters or expressions aren't allowed in this field and I have yet to figure out how to push a variable
recent by Boonz  ·  Jan 15 at 8:50 pm
240
When trying to setup communications to import tags I am getting an error of "Driver Not Ready".
Also, when I try to set up tags individually, the application is unable to read from the PLC to choose the appropriate I/O.
I have noticed that I am not getting a value next to my driver, but I am getting a zero next to my port. I cannot find a reason for a value bein
694ef6ae48b2a
recent by Dave - VTScada  ·  Jan 6 at 5:20 pm
12345 ... 29
