188
1.27k
16
122
Main [
If Latch(AbsTime(1, 5, 0), AbsTime(1, 1, 5));
TagObj3 = Scope(\Code,"Fq");
ScriptObj\Value = TagObj3\Value;
{this works, changing TagObj3 value in VTScada Tag Manager reflects in the Script tags value.}
TagObj3\Value = 5434; { this do **not** work, I cannot see Fq tag changing its value to 5434 }
{ Is it changing its value to 5434 but o
134
I'm trying to figure out how to bulk generate/edit tags, and got stuck here.
It seems for every new tag, vtscada generates its own custom hash ?
I tried to use python to generate some random string, but faced error as shown in picture.
Tag name found that doesn't match tag file hash
What is tag file hash, how to generate it.
68246fe9d2930
208
Attempting to connect to HiveMQ Cloud MQTT Broker which requires TLS. I've connected to other MQTT brokers that didn't require TLS with no issues. I've created an MQTT Client Driver and created a TCP/IP Port child. None of the TLS settings were successful so I download a pem file from HiveMQ, converted it to a crt file using OpenSSL and imported it to my PC but it does not appear in the list o
210
When the user looks at the trend curve, he wants to see the two identification lines of high alarm and low alarm, and when the user looks at the temperature for a period of time, he can clearly see whether the data is abnormal。
See picture
In subsequent versions, can the function of alarm identification of graphs be added?
Than you
6805f9d0df281
recent by Vic  ·  Apr 25 '25 at 8:03 pm
206
Hello, I am new to using VTSCADA but have experience with SCADA software in the past. For our application, we would like to utilize VTSCADA to create data driven maintenance packages utilizing Maximo to create Work Orders.
An example of this application is:
HVAC filter dp is monitored and there is currently an existing job plan in Maximo to do the PM to replace the filters. VTSCADA would
recent by Vic  ·  Apr 25 '25 at 7:48 pm
213
Hi all,
I'm implementing alarms in VTScada at a water treatment plant, but I'm facing some problems. I want to set up alarms to occur at certain threshold values and notify operators via email. But I'm not certain on how to correctly implement alarm priorities and ensure proper notification is being sent.
Here are my queries:
What's the best method for configuring alarm priorities in
135
J_Hob posted Mar 19 '25 at 7:21 am
Hi All,
I am having an issue with a daily report that i have configured.
My understanding is that a daily report is a sum of the values accumulated for a each of a selected set of tags within the time period you specify.
Very simple i have four tags which values change approx. 4 times a day, in theory these values should be added together and displayed as a 'Daily Total'... Right?
67da704e08294
recent by J_Hob  ·  Mar 19 '25 at 11:56 am
118
Need to enroll my users using SCADA to Entra Office 365, this creates a new profile at computer. Will users settings and licenses work afterwards? Same computer. SCADA was installed locally and will be on our network which creates a new profile for user.
recent by admin  ·  Feb 24 '25 at 12:47 pm
156
Andres_Citi posted Feb 5 '25 at 1:33 pm
Hi all,
I have an application in which each tag has a context folder with tags just for internal use. That is, tags that will be needed for some widgets but we don't need the final user, in this case, the operators to have access to them.
Is there a way to hide them from the list of tags but still have them do their job?
Thank you in advance.
329
Hi, Im wondering if there is a way to build one popup, and each time its opened, depending on what screen its on, if there is a way to assign a different UDT or tag for it to look at. For example, if i have 3 displays that all show flowmeters, can I use a single popup instead of creating 3 separate popups and just have the tags that it looks at, change based on the page its on??
recent by tlsnyder98  ·  Feb 6 '25 at 4:28 pm
69
Boonz posted Feb 5 '25 at 5:21 pm
This would be a simple thing to add. Have a system properties that sets the default width of drawings pipes and lines. So you dont need to always change the width if you don't like the huge default size of pipe drawing tool.
308
I want to use vtscada for a project for the first time.
There is 150 individual machines(workstation). Where we need install vtscada on each machine. Each machine would have around 50 tags. And need 1 server at control room where all the machines can be access. Beside that need remote access 1 user, alarm notification SMS EMAIL. Big Remote screen at plant floor.
Please help to s
recent by Joel.David  ·  Feb 3 '25 at 7:49 pm
135
Hello, I am trying to create a control screen on the left hand side that auto populates depending on what equipment is present on the main screen. So if we have 3 pumps on the main screen, the side screen should autofill with 3 pump start/stop button that correctly reference the names of the pumps.
Could anyone point me to a resource that would help with this setup?
Thank you.
recent by TomE  ·  Feb 3 '25 at 10:17 am
123456 ... 10
