579
2.03k
30
122
tmills10 posted Jun 30 '22 at 1:13 am
Hey everyone, I have a weird issue where if you click on a value (bringing up the trend popup) it brings up every notebook under the parent. I think it happened after I created a trend group but I'm not 100% sure. I have since deleted the group but still, all the notebooks show up.
Has anyone seen this before?
Thanks!!
62bcea47d51be
recent by tmills10  ·  Jul 6 '22 at 4:40 am
163
Tames posted Jun 24 '22 at 6:57 pm
I am trying to open a page in Notepad++ and make edits to the code to change the page when displayed. I have been having a few issues with this.
1) When I edit the .src file and save the code and then open the page in VTScada it does not change. I will close the Idea Studio, close the file folder, or anything else that might have it open that could keep it from updating.
2) T
recent by Tames  ·  Jun 24 '22 at 9:44 pm
148
When configuring an application and choosing "from a workstation" (via advanced), if I enter a loopback address (eg. 127.0.0.2), or a hostname (via hosts file) that also points to a loopback address, it seems vtscada does not make any attempt to connect to RPC to this address. The use case here is a local proxy server connecting the TCP connection (via port 5780) to a remote VTScada server. Is th
128
Tames posted Jun 17 '22 at 10:11 pm
I am trying to get a Text to load a value of a main TAG. for example a AlarmHi attribute.
I have made some progress but I am having issues with the last little bit to get the final value.
The page has 2 parameters
Tag0(Tag)
TagAttribute(Text)
The one way I can get the expression to work on the text is:
Format(7,1, Tag0\AlarmHi)
What I want to happen is in t
recent by Tames  ·  Jun 20 '22 at 4:24 pm
153
I downloaded VTScada to try out with a Delta PLC, Delta is what we primarily use. According to a PDF on Delta's website there should be the ability to add a Delta Driver in the Tag Browser. The Delta driver isn't listed as one I can add. Here are the instructions I found on Delta's website. Anyone figured this out?
https://filecenter.deltaww.com/Products/download/06/060711/Manual/DELTA_IA_OMS_
137
ftuquabo posted Jun 14 '22 at 7:40 pm
Started creating tags that will be connecting to a Siemens PLC and I am getting an error about Tag Address I'm using. Can someone tell me what;s wrong with this PLC tag's address format?
Could there be an issue in the Siemen's tag driver settings?
62a8d5ed2db1f
384
Does VTScada's built in e-mail client meet the security requirements Google describe
here ---> https://support.google.com/accounts/answer/6010255#more-secure-apps-how
and here ---> https://support.google.com/accounts/answer/3466521
Many of our customers are using gmail to send alarm notifications. We've upgraded some of them to VTScada and are not sure what will happen when google
recent by mike_yung  ·  Jun 8 '22 at 8:49 pm
207
abec34 posted May 26 '22 at 11:46 pm
I am receiving a value of 273 from the BACnet driver but within Wireshark capture I am getting no errors and can see the correct Value being returned.
Any idea why VTScada is giving out an error code of 273? The tag I created has no value which I am assuming since the driver is getting a value of 273 and not 0?
Here is what VTScada is showing:
but here is the proper value comin
6290026f65914
recent by abec34  ·  Jun 6 '22 at 11:26 pm
128
Hi all,
This whole OT/ICS world is pretty new to me but I am trying to pick it up and work my way through it, but just looking for a bit of help with something.
I am trying to set up a virtual lab to demo how easy it can be for a hacker to change values and mess with OT equipment if the network is not correctly secure. Originally this was just with getting remote access to a private comp
164
Tames posted May 25 '22 at 9:38 pm
I have noticed that if I am using a text box that I am unable to type ".00" to the end of a number, really any length of that .0, .000, etc. If I type it in the program automatically removes it.
It is a small thing but it creates uniform numbers when I have to list of a few of them and the rest have single or double decimal places.
If there is a way to turn that function off?
recent by Tames  ·  May 26 '22 at 4:22 pm
