579
2.03k
30
266
The Modbus User Map Register Settings are correct and the frequency tag is working correctly; however, tags IA, IB, and IC are not updating properly on VTScada. Shown herein.
As the expected value is appx. '0.54' on SEL and '1' is shown on VTScada, I was looking to increase the resolution as this could resolve potentially but couldn't locate. I showed the 'Scaling' for IA tag properties if t
6182d9625901f
126
aditi2397 posted Nov 17 '21 at 5:06 am
I want to simulate the environment of PLC and HMI communication on VTScadaLight using GE Fanuc Series 90 driver so that I can run a virtual PLC using port 18245 and HMI on the same computer. Can anyone please tell me whether it is possible and if it is then how should I work it out.
Thank you.
54
I find the "Alarm Configuration Structure" in the webpage .
There is a "Custom" in the structure. Where should I key in value into the "Customer"? I can`t find a place in the "Alarm Properties TabPage".
Thank you.
64
aakram posted Nov 10 '21 at 7:16 pm
Resizing HDV popup window pauses live data view. The same happens when this window is minimized and restored. This behavior started after an upgrade from version 12.0.32 to 12.0.44.
132
How to calculate the local disk space that will be used by VTScada tag`s historian?
For example, I have an application including two analog tag. Every minute the two analog tag data will be store into VTScada internal database by historian.
I want to know incremental local disk space that be used by historian and internal database for one hour and for one day. So I can prepare a appropr
recent by Michael  ·  Nov 8 '21 at 6:34 pm
147
flagshang posted Oct 11 '21 at 5:59 am
VTScada can use ActiveX like Shell.Explorer in the help page.
https://www.vtscada.com/help/Content/Pro_Functions/ActiveX.htm?Highlight=activex
How can I write a ActiveX that does something for VTScada? What is the interface or protocol? I need usermanual about this. Thank you .
recent by flagshang  ·  Nov 2 '21 at 5:55 am
411
Paul Bailey posted Sep 23 '21 at 5:32 pm
After obtaining a certificate and verifying your domain, GoDaddy will supply you with the following files:
generated-private-key.txt
generated-csr.txt
Security Certificate.crt
(“Security Certificate” would be replaced with random characters)
You should be logged into Windows as an account with administrative privileges for these steps to work.
Place those files
158
foxychen posted Oct 18 '21 at 11:01 am
HI
I have designed a Tag group, there are about 50 tags and a modbus driver, a serial(TCP/IP) port in the group, each tag mapping to a same table to the real device.
After I copy tag groups and set different station ID,
When I connect to one device, all tags read values in one second,
when I connect to two device, some tags read values in one second, but some tags read values in
81
Careyh posted Oct 28 '21 at 11:03 pm
Can VTScada poll extended history from a Floboss / ROC RTU? Its not in the help anywhere
151
I'm using VTScada to run an application linking this software to MATLAB through Excel.
When writing from Matlab to Excel,and Excel to MATLAB, everything works fine.
When using VTScada as DDE Server,and writing data to my Excel, by using the following formula:
=VTS|'NewApplication'!'L1\Value'
I get a message telling me that I have to open VTScada,even if the problem is already runni
226
soh posted Sep 4 '21 at 4:28 pm
I already setup a simple test project for thin client remote access.
I able to connect remotely using laptop via the URL given ( VIC/MIC/anywhere.
Unfortunately i not able to access remote using mobile browser.
Please advice
6133905b305d7
