188
1.27k
16
124
TomE posted Aug 22 '23 at 8:54 pm
Has bugged me for a while, however never spent time on looking into it... is this a bug or am I missing something?
When selecting one of the stock Images, i.e. arrows that have a blue infill, when I try to assign another colour to them it is as if the colours "merge" to make the resultant colour see below example, blue arrow, configured to yellow, shows green..
64e512271765e
234
Anbarasu.A posted Aug 22 '23 at 6:07 am
I was trying to add opacity expression in momentary switches, when selector switch changing the position according to that Momentary switches will fade.
Anybody pls help me to write a expression...
64e44278c4864
recent by TomE  ·  Aug 22 '23 at 1:59 pm
86
Glenc posted Aug 8 '23 at 9:23 pm
I have one computer that when I connect to the remote scada server using a web browser to the web address (i.e. http://123.123.123.123:88) the display is complete. However, when i use the VTSX client on the same computer many of the icons are not rendered and the topographical background is not present. At first i suspected a video driver update but the fact that it works with the web browser
201
jced226 posted Jul 31 '23 at 3:23 pm
I am trying to pull more tags from a P2-550 CPU from AutomationDirect. I looked through the PLC Program on productivity to see the data that VTScada should be pulling. However, it seems to be only pulling two tags from the CPU and not the rest. The tags show a value of 0 but should be showing numbers. I tried accessing Modbus Poll to see what would be the problem, but Modbus Poll isn't
recent by Tames  ·  Jul 31 '23 at 9:46 pm
337
Tames posted Oct 26 '22 at 4:20 pm
Does anyone have a working example of a basic page using a gridlist function?
The example in the help documentation does not work when copy and pasted into my code, and I have been the extra things to get it working but in the end the Gridlist is not pulling the example list of Data[#][#] or Title[#] information past the first inputs.
Is there something I am missing?
63594fd793e68
189
Is there a way to have a dynamic place holder to call a specific widget that is embedded in a popup page. i tried this but it does not link is there a specific function for this? Below is what i tried not the full source code just the specific areas.
Path = concat("WidgetInterlock", Replace(\GetPhrase(Taglink), 0, 12, "-", "_");
GUITransform(12, 148, 579, 53,
1, 1, 1, 1
202
H2OTom posted Jul 4 '23 at 5:11 am
Hello! I'd like to setup a digital alarm or status for ANY active alarms that are unacknowledged, and not shelved, that have been active and unacknowledged for 5 minutes or more.
Any direction would be appreciated!
110
When using the online help document the search function in a Microsoft Edge browser will not work properly.
For example, I can search "Anywhere" and I will get 97 results. I can see that most of the results are pages for the Anywhere Client feature. But if I search "Anywhere Client" I will get 0 search results.
If I switch to a Chrome browser and search "Anywhere Client" I will get 76 s
recent by Tames  ·  Jul 11 '23 at 6:37 pm
200
Are there any rules/algorithm for scaling in VTScada to adjust the values from the PLC to the real values?
At the moment we are getting some values but we have to adjust them to the Output we want to have... Can we do that by scaling is there another possible solution?
Thanks four your expertise and help!
148
Stefan_Neamtu posted Jun 23 '22 at 7:39 am
I am using a gauge widget and HDV for trending a tag from a modbus device.
The scan interval is set for 60 seconds, i want to keep the last read value until the next read in order not to have gaps in the HDV trend line. I am using the following settings:
Despite those settings i am still getting gaps in the graphics.
I have tried to use the "Hold" option in the SERIAL tab, bu
62b40a28a866d
