A customer asked: Can I create custom trends and share then with team mates without configuring the application?
Does anyone have the well simulator change group from the OC_Workbook_v11.pdf ? The example requires the well simulator.
We currently run ge with primary, secondary, and a historian server.
What would be good specs to have server wise running the dual premium server setup 10-25k tags and 15 thin clients. Thanks for the input. Any brand you prefer over another?
Regarding the HDV excel export, are there any options of modifying the column number of the report, like removing the timestamp column etc... ?
Hi there, Is it possible to create a pop-up page that will close if clicked outside ?
Hello, is there a way to create inside a page a drop-down menu containing links to specific pages ?
For example I would have a button named "Field Devices" and when i click on it - to show a drop-down list - Device 1 page , Device 2 page ... etc
Ketul
posted Jun 8 '22 at 8:24 am
VTScada stored all history data in its default Historian.
I have used that default historian only in my application and I have logged some values with the default Historian.
How Can I read this store's historian tag values in MS SQL Server?
I have installed the VTScada ODBC Driver and also add SQL Server Driver in User DSN on ODBC Administrator.
This SQL Server Driver I have conf
Ketul
posted May 25 '22 at 5:29 am
I have secured my thin client link with the SSL X.509 certificate.
(I have made a new CSR request with my host+DNS name. I have validated the request from my CA & they send me the key and certificate. That I have to do Process Reply in SCADA and it successfully proceeded. I have added the SSLCertName property in my APPRoot file and restarted the application and ticked the SSL (443 port) op
I want to create a custom Site Map Icon.
I would like to click the site icon on a map and have it take me to the related display for that site.
Here is what I have.
I have a Context tag. On the Display tab I entered the Lat and Longitude.
I entered the page name in "Custom Details Page".
When I click the Icon on the Site Map display, it opens my display as a pop up. I want it to
Ketul
posted May 23 '22 at 12:33 pm
How can I import one machine history data to another machine. I want to copy all historical data of trends & reports onto another machine.
I have copied the Data folder of my application to my another application and replace the folder but I'm not getting Historial data inti it.
Is there any extra steps needs to perform here?
Hi ,
The contexte: I got a station (on site) and a control station (not on site). I want to know if is possible to revoke the control for the station to let the entire control to the control station. It will allowed the control station to change the I/o statues and do what they need to do and don`t let the station (on site) change the I/O statues.
Thanks for any help
TonyTVu
posted May 4 '22 at 5:02 pm
What Driver should I use to the MicroLogix 820? On the VTScadaLight...
Does the release of your Graphic Terminal Licence ( https://www.vtscada.com/documents/datasheets/Datasheet-VTScada-GraphicTerminalLicense.pdf ) mean we'll be getting pop-up keypad/keyboard input widgets soon?
Dear Sir,
I will reset windows 10 with clean wipe. Please guide how to take backup and restore vtscada light
In VTscada, is there a way to link a tag to an alarm acknowledgement button in the alarm window that can turn on or off a tag in the PLC?
Thanks.
Ketul
posted Mar 24 '22 at 11:04 am
I want to add my custom VAM Icon for my application to display in VAM site lists.
where and how can I add my custom image or where I can modify the existing image for my single application only?
Jerry
posted Nov 3 '21 at 8:03 am
How to exit project program by button,Which script is associated under the button? Can you give me a sample,thanks.
IS there anyway to fix what you see below ? There seems to be a link to something, but it never allows me to go anywhere.
We use Google Drive to house information of various lift stations utilizing a program spawn widget. Here's the breakdown of that program spawn...
This is just a shortened down version of what's included in that box for program spawn properties. There are 64 lift stations, so the list below is definitely longer. I created a folder for LS71 because at the time we did not have a dedicated folder
Just wondering if anyone has had any luck using VTScada to connect to the BRX Controllers from Automation Direct. I love the PLCs but I am only successful with MODBUS comms which are limited to specific registers. I create my own User Data Types (UDT's) that are mappable to EIP Locations to which you can use Ethernet Explicit Messaging to. I am very unfamiliar with getting the communications to
