Tames
posted Feb 21 '23 at 9:40 pm
I built a Lufkin SAMS controller inside of my VTScada and it automatically built all the TAG's as either Analog Status or Digital Status TAG's (Legacy TAG's) I am trying to set the lowlow / low / high / highhigh limits for the Analog Status points but I found that these types only allow for a Low/High alarm, but in the support document the picture used for this TAG is the Calculations I/O Analog
I have been trying to set up a connection between VTScadaLite and a Allen Bradley plc using Ethernet/Ip. From what I can gather I am using the correct driver and tag set up. But the digital [IN] does not register a value coming from the PLC.
The PLC can be pinged and ports have been enabled with all firewalls turned off.
The running PLC program is being monitored using the CCW s
I was following the quickstart video and I can not go further because “draw” is grayed out. Is that not available in the Light version?
How to proceed to visualize this parameter?
Next hurdle for me. Learning how to read a value from one MB device, then, if the value has changed more than deadband, write that value to a different MB device.
example: read register 7033 from MB ID 15. IF value change exceeds db (0.005) then write the new value to register 7040 at MB ID 25.
Testing VT SCADA (the light version) to see if it can be used to manage several irrigation canal systems using Control Design CD120 RTU's. These are FM radio devices. They have a range of registers (47033-423039) designated for floating point value storage. These are 32 bit (4 byte) registers.
For example, modbus ID 20, register 47033 (0-based) currently contains the value 1.4839. A quer
I wanted to reach out to others to see if they have been having similar issues. I'm located in Tuscaloosa, Alabama at the Hilliard Fletcher Wastewater Treatment Plant. I've got a few different ways to access VTScada, but the one way that has been giving us all fits has been accessing VTScada through the Anywhere Client. Our plant operators access VTScada through Anywhere Client. I can access thro
jxa
posted Nov 30 '22 at 4:17 pm
Can I get some help in defining a SQL Driver template for pulling values from another VTScada system?
ODBC driver is installed, user account with remote data permissions created, realm created, DSN defined, connection verified.
There is no option in the database type list for VTScada. What should be chosen here?
I made a probably incorrect assumption that a query should follow the for
I am trying to connect and pull data from a multismart via modbus. I can ping the IP address of the multismart and the Modbus address for the driver is 1, but I am getting an error code of 260 from the IP address and an error code of 531 on the driver. I tried connecting to the multismart with a modbus scanner via TCP/IP but I cannot pull any data from the registers.
Tames
posted Nov 1 '22 at 3:35 pm
When dealing with a GUIText inside of a widget I can see from the help document that there is the Options section that allows for control of font size. The only issue I have is that the options are for;
no change
change based off vertical scaling of the page
scale to topmost scaling, ie. the page
I am trying to get a GUIText to scale inside of a widget so that I can change the widget dimens
crd
posted Nov 15 '22 at 3:09 pm
The notification email is attaching the wrong user when sending the message.
Example:
Original forum entry (user crd):
crd posted 1 day ago at 10:05 pm
I would like to change the alarm code to the beginning of the message, as to allow the user to 'Like' the alarm message and acknowledge it.
This currently works if we remove all of the text except the date, but that introduces the pro
lucy
posted Nov 8 '22 at 2:02 am
What are the Remote Data access ? Which licenses need to be purchased? Remote access licenses will be enabled
What is the Remote configuration & Remote Idea Studio? Which functions are specifically included
Thank you and look forward to your reply
Jason
posted Oct 20 '22 at 8:28 pm
I have been tasked to make a standard VTScada template. This will get used in different applications. How it is supposed to function is that it will list all the shutdown conditions and it will display which ones are in fault (easy part). Then when you click on each shutdown it will take you to the faceplate of the device it is connected too. The problem I run into is when trying to have it all p
crd
posted Oct 24 '22 at 10:35 pm
I am looking to get query data from a PostgreSQL database (not a VTScada database). Is there any way to do this in VTScada?
How do you have a script always running in the background?
I want to link F8 key to silence alarms.
bbaer22
posted Oct 11 '22 at 9:01 pm
I would like to use a Text Change 2 state, and when it's in the 0 position or non energized state I want it to show one word in a certain color and in the 1 position I want a different word and color. It doesn't look like it would be tough, but I can't get it to accept a tag. I tried a bunch of different kinds of tags and it's just not accepting any of them. I would like to use a tag for this sin
Ketul
posted Sep 29 '22 at 7:51 am
I have run two applications in my VTScada called 'App1' & 'App2'. In my 'App1' I have made some pages in Idea Studio called 'Page 1', and 'Page 2'.
In my 'App2' I have made one 'Home Page' from where I need to open 'Page 1' of 'App 1'.
How can I call this page from another application?
I have a SCADA system that is not connected to the Internet, like most every SCADA system I work on. I have copied the Slippy Map Tiles for my area to my SCADA server. However, my map icons do not appear on the Map. No matter how far I zoom in or out.
How do I get my Map Icons to appear if I don't have an Internet connection?
Tames
posted Jul 20 '22 at 6:47 pm
I have taken over a job and the previous creators used:
SState0Color
SState1Color
SState2Color
SState3Color
to pull in the colors form the style settings without pulling in the alarm color override. I have copied and pasted their code (from a working widget) and pasted it into my own but it does not work.
The code is:
\Root\Value == 0 ? SState0Color : ( \Roo
This section of the help (linked to) tries to refer me to Microsoft for details on how to get a signed SLL certificate but the url which used to give that information now tries to upgrade me to Windows 11.
Please reply with the instructions for processing a reply to an SLL signing request & arrange for this to be added to your online help. Thank you.
https://www.vtscada.com/help/Con
Tames
posted Aug 31 '22 at 3:51 pm
I have been looking for a feature request page/section but I cannot find one. Is there anything like that kicking around?
Thanks.
