184
1.26k
16
77
Joseph "JD" Rhodes posted Mar 22 '22 at 7:52 pm
We use Google Drive to house information of various lift stations utilizing a program spawn widget. Here's the breakdown of that program spawn...
This is just a shortened down version of what's included in that box for program spawn properties. There are 64 lift stations, so the list below is definitely longer. I created a folder for LS71 because at the time we did not have a dedicated folder
623a26fc22543
237
AC Salyers posted Mar 20 '22 at 7:48 pm
Just wondering if anyone has had any luck using VTScada to connect to the BRX Controllers from Automation Direct. I love the PLCs but I am only successful with MODBUS comms which are limited to specific registers. I create my own User Data Types (UDT's) that are mappable to EIP Locations to which you can use Ethernet Explicit Messaging to. I am very unfamiliar with getting the communications to
115
Joseph "JD" Rhodes posted Mar 16 '22 at 12:16 pm
Analog Input Tags, Analog Status Tags, Digital Input, Digital Status, etc are all considered legacy type tags according to the VTScada Help files. It is advised to use I/O and Calculations Tag instead. Why ? Is there anything wrong with using legacy tags ? What are the main differences from legacy tags to i/o & calculation tags ?
121
If you notice, I have two parent tags called USGS & USGS 2. These tags point to a different USGS site location (Cribbs Mill Creek & Black Warrior River). From that parent tag, I've made two child tags with two analog status. I have an analog status for pulling the discharge, cubic feet per second and the gage height of both cribbs mill creek & black warrior river. How do I associate t
6222128c13f7a
118
Ketul posted Feb 28 '22 at 12:53 pm
I have entered string entries in my IO calculation tags.
I want to show the indicator as a green label when the written value from the VTScada to RTU gets written successfully.
As shown in the pic above, When this string value gets written successfully into the RTU from SCADA, I want to show the indicator as Green.
How can I do that? Please guide me.
Let me know if any other
621cc58057f92
131
Ketul posted Jan 27 '22 at 5:12 am
My aim is to open the date picker window when the user clicks on the one bitmap calendar image icon.
Then after the selection of data, it will display on one text box.
I can draw the text box, calendar icon in the idea studio.
How can I open the date picker window when clicking on the calendar icon?
Can you please guide me on how can I open a date picker window for u
61f228a33d158
recent by Ketul  ·  Jan 27 '22 at 7:47 am
43
Hello, i am trying to dynamically set the PageHeight property in the source code of a popup.
its seems you cannot run an expression in the variable declaration of the source code.
I can put this in the main function PageHeight = PickValid(Type_PID\RemSP, 0) == 1 ? 709 : 577 ;
But it seems it doesn’t resize the popup.
Is there a way to change the height of a popup with an expre
548
Ketul posted Dec 21 '21 at 11:56 am
I want to make an image blinking when the digital tag property change to 1.
When the digital tag value change to 1, My image needs to blink on the screen.
How can it be possible and how can I configure the image to do so?
recent by Ketul  ·  Dec 22 '21 at 12:37 pm
110
miahbrown posted Dec 16 '21 at 9:29 pm
I'm new to VTScada and currently using VTScada light and watching videos to get started. Two quick questions.
The text widget correctly reads a tag in the PLC but displays a ? at the end of the text. How do I get rid of the ? at the end of the text?
How can I change the color schemes for the gauge widgets? I'm using the Arc Meter gauge widget which is blue but don't see any
109
Ketul posted Dec 1 '21 at 9:39 am
I want to read data in VTscada individual tags from MS-SQL.
I have created database & tables in MS-SQL. I want to read some string, integer data in VTscada tags.
Also, I need to know SQL addressing to read data from MS-SQL in individual tags in VTScada.
Can you please guide me on this?
sql
1 ... 78910
