131
Ketul posted May 20 '21 at 11:23 am
I have created context groups for Pump1, Pump2, Pump3...and so on in the tag browser.
My aim is to on idol studio screen Pump tiles is enabled/disabled accordingly context tags enable/disable.
e.g. If I have enabled context tags for pump1 & pump2 only then only 2 pump tiles widgets will be shown on the screen. Rest will disappear.
How can I achieve this ?
60a638885cb72
recent by Ketul  ·  Aug 30 '21 at 12:25 pm
50
I need enable/disable widgets based on selector switch mode.
ex. When I select auto mode in selector switch then all other pump control widgets (ON/OFF switch) needs to be disabled and when I put selector switch in Manual mode then I have access to control pumps ON/OFF switch.
How can I make it?
238
Jerry posted Aug 19 '21 at 7:09 am
Hello, I have a VTSCADA question to ask,thank you
Tag01 is the address of 40001 from the PLC. Now I want to set the bit2 of Tag01 to 1.
I failed to do this by setbit () ,Please tell me how to achieve it,thank you
611df4502643b
recent by Jerry  ·  Aug 23 '21 at 4:20 am
116
AC Salyers posted Aug 20 '21 at 3:32 am
Im trying to figure out how to embed text (Like an on call list) that is from a live document. I am currently using and Access Database that is pulling from an Excel spread sheet but I am using so many tags for every name and number it just doesnt make sense to do it this way. I think Im using somewhere around 20 tags just to have five people on the list and Im about to do this for a couple oth
236
My first post to this forum!
I have set up a DNP3 driver and configured a Digital tag. My outstation device is set up to provide a binary tag w/ packed format. However, I am not able to get a response from the index=1 tag on my VTScada Application Dashboard.
Has anyone successfully setup a DNP3 binary tag (w/ "packed" format) in VT Scada?
Any input would be MUCH appreciated.
Tha
152
With the sample in the helppage(file:///C:/VTScada/VTSHelp/Content/Pro_Functions/ActiveX.htm?Highlight=Shell.Explorer), I can loading my webpage(test1.html) into the vtscada page as below code.
Now I want my webpage(test1.html) background is transparent so that I can use vtscada page background picture as my webpage background.
Maybe this is related to my webpage(test1.html) and ActiveX("
recent by flagshang  ·  Aug 12 '21 at 4:07 am
743
Is OPC UA Driver supported in Light Version? I cannot get it to connect to a server: status not refreshed.
On the I/O address assist button seems grayed out and I cannot tell what is failing.
Tried from same client host UAExplorer and it connects fine.
I selected Anonymous and no certificates. Is this configuration not supported?
Is the a log file somewhere I can view?
372
Brent Saunders posted May 5 '21 at 7:28 pm
We are incorporating opendnp3 outstation into our product. We are sending changes with time. However, all logs and trends show points changing at time of reception rather than the time sent with the point change. We have used wireshark to verify the unsolicited change message is going out correctly. Is there a configuration in VTScada to tell it to use the transmitted time rather then the tim
226
Ketul posted Jun 1 '21 at 6:54 am
How can I enable all the DNP3 variations for Analog Input & Analog Output status without enabling a direct poll?
-Default is showing 'All variations'. How can I add more variations for analog input & analog output? I want to use a 32-bit variation in all tags. How can I make enable this?
Where Can I found the button for the DNP3 event poll & the Integrity poll? I want t
60b5cb74b00be
181
The OPC-UA specifications define a Method NodeClass: https://reference.opcfoundation.org/v104/Core/docs/Part3/5.7/
A method defines a callable function which can be invoked using the Call Service mechanism defined here: https://reference.opcfoundation.org/v104/Core/docs/Part4/
In practice this means I can implement a method in my OPC-UA server and invoke it from an OPC-UA client o
209
New to VTScada and in a new employer who has a device with VTScada (unsure lite or not) that will now not start. Embedded Win7 and the loading splash screen starts for a few seconds then goes away without any error or remark.
Have tried debugging the issue the past day by viewing forums, manuals, etc but not finding anything.
Biggest issue is I'm not sure they have the knowledge themselv
615
Natashia - VTScada posted Mar 2 '17 at 2:46 pm
Question posed on our website: Any work on supporting/offering OPC UA? MQTT? I like the internet server & redundancy. What I may want to do is integrate your product to display VTScada HMI screens. How do I populate the screen(s) with real time data? I have in place all the data acquisition & can provide it to your internet server(s) via??? I'm thinking in terms of Opto 22 HMI servers wh
154
Kevin Way posted Jul 27 '21 at 3:47 am
Hey all, I need to use the plotxy function to display a xy graph. Has anyone use this before?
My main question would be. How to generate the X and Y arrays. Would you use the GetTagHistory function to generate these arrays?
recent by Kevin Way  ·  Aug 3 '21 at 8:03 pm
554
I am working on some software for my company. Field technicians can enter well pump readings and the chlorine residual through an Android / iOS app.
The backend of the app is written in Node.js.
I'm trying to get the pump reading from VTSCADA and send it to our app.
I wrote an API (documented here )
I also wrote a CLI (documented here )
Is there some way we can take the pump r
116
Ketul posted Jul 22 '21 at 1:49 pm
I have created parameterized pages. I have assign parameter values in it of my created own tag type.
When I open my parameterized popup pages it looks like as below.
In which "SOV-1 Status" is just a text.
How can I make this text as parameterized text so that when I open my pages it will show me SOV 1 Status, SOV 2 Staus, and so on...
In my tag link widget I need to set tex
60f968cab0c85
recent by Michael  ·  Jul 26 '21 at 11:37 pm
254
tmills10 posted Jun 3 '21 at 9:15 pm
So trying to read values out of an INT table from a PLC5. The positive values all read fine but if we try to read a negative integer value we get the wrong data in VT, usually a value of 6553. To get around this we just did a MOV from INT to a FLT and it reads fine again.
What would be the limitation of reading negative integer values?
recent by DanW  ·  Jul 21 '21 at 3:25 pm
53
jfrye posted Jun 28 '21 at 5:21 pm
I am trying to setup MDS Diagnostics Driver tags using TCP/IP ports, everything is on the same subnet, I have tried using the only ports I can find documented in the manual (GE MDS iNET) which are 30011 and 30010, but have no results. Have also tried the default 3001 and 502. Any suggestions? Thanks.
465
AC Salyers posted Apr 1 '21 at 8:20 pm
I use graphic editors quite a bit and some features that come in extremely handy that are absent VT Scada would make the work flow more seamless and less tedious in many cases especially when working with multilayer graphics.
• The first I would like to suggest is the ability to lock layers while editing pages or widgets so that they cannot be moved or changed while they are locked. To
