183
1.26k
16
118
This is a question I was asked by a customer recently:
Q – What is the easiest way to do a daily pump run report for 5 years?
A – The built-in Pump Activity Report should work. It provides you with activity over the entire time frame, not daily over x years. You'd have to run it for the previous day and then have (5*365) = 1825 previous periods. Not allowing for leap years.
834
9
jedwards70 posted Apr 23 '18 at 6:51 pm
Allen Bradley tag creation, if I create a tag for Bool in program, how do I set up address for tag? video is different than what I am seeing.
This is in Softlogix PLC simulator.
169
Single Application on 3 different Servers that are connected via radio link.
Call them ServerA, ServerB, ServerC
3 PLCs (actually more but this is good enough) each PLC is located in proximity to its similar server
Call them PLCA, PLCB, PLCC
Default configuration is ServerA - if primary does polling to PLCA, PLCB, PLCC. If ServerA goes down ServerB takes over all communication a
recent by Ralphf  ·  Oct 12 '18 at 9:02 pm
178
For Testing Purposes, I would like to Enable or Disable an Automatic SilenceSound() Function so that I hear 5 seconds of the Alarm Alert sounds and then they are Silenced without Operator intervention. I don't want to Acknowledge or take any other Actions.
Any suggestions are much appreciated!
Thanks, Paul H. Bott, P.E.
222
Ralphf posted May 8 '18 at 6:56 pm
With Analog Status you have High and Low alarm setpoints built in so you don't have additional setpoint tags go against your tag count. How do you then refrence these setpoints inside the digital status tag to a numeric entry so that users can changes these without having to go into tag browser?
Is this the design that for adjustable setpoints in HMI it requires tags (that go against the cou
127
andrey20 posted May 5 '18 at 8:13 am
Currently we are on the way to deploy APQP process with our supplier for my company automotive project. There are something as below:
I'm reviewing a supplier timeline and have a concern as below:
as you know, in PTO we need to get samples from supplier to proceed it.
Sample should satisfy DIM,Function & Material, the problem is i don't know how to define those samples i
596
Hi there,
I have recently ventured into trying VTSCADA and I really REALLY like it.
I use scada systems for very simple lab based data aquisition and control. Very seldom more than 15 tags.
My challenge is that I need to aquire a timestamp ONLY when a certain tag value changes. The tag is basically a totaliser (Analog input from MCU). This is very simple to do in the likes of SCADABR
recent by Michael  ·  Apr 27 '18 at 3:58 pm
252
As described here
https://www.trihedral.com/sustainable-scada-system
Distributed Local Historians – The County was also concerned about the potential loss of data should the connection to remote sites be lost. In response, MPE configured the application to allow for use of VTScada as local HMIs at all remote stations. Once VTScada is deployed as a local HMI, if the station is cut
172
adamlevine posted Apr 16 '18 at 10:26 am
Custom Colors
Hi. Here is my MWe:
documentclass [12pt, Dvipsnames] {Amsart}
usepackage{latexsym, AMSSYMB}
usepackage{xcolor, COLORTBL}
begin{document}
{color{orange} $ varphi (x) $}, {color{RedOrange} $ varphi (x) $}, {color{red} $ varphi (x) $}.
end{document}
Now, I'd like to darken the second orange, but I can't
To create my own custom color. So, I searched for a
445
Hi All, we are looking at a project where we want to host VTScada on a remote AWS web server and have it amalgamate several remote well sites connected to the internet with GSM modems. Has anyone deployed a system like this with VTScada before? We've done similar with other platforms but we're keen to move forward with a VTScada solution for this one. Any tips or info is appreciated!
326
JustinW posted Mar 14 '18 at 11:20 pm
Is there a way to change the color of the text based on some set-points for data coming from an Analog Status tag? I'm thinking you would use the "Text Change (4 state)" widget, but I can't figure out how to set the values for the different states.
For example, I would like it to always show the tag value, but change from blue when it's below 110.0 to green between 110.0 and 120.0, and red
recent by JustinW  ·  Apr 3 '18 at 12:12 am
104
Rayancaleb posted Feb 24 '18 at 8:30 am
HI,
I'm thinking about changing vehicles, I currently have a Xsara Picasso Gasoline 90 Cv. I want to buy a C4 Picasso Diesel, I think the one that better fits me is the 110 HP, but I have the doubt between the manual change or the CMP, I have heard some comment, about the latter, and I have doubts. Can somebody help me????
Thanks
I did not find the right solution from the internet.
176
ewood1972 posted Feb 14 '18 at 4:51 pm
We are installing VTSCADA for the first time in our district and will be setting it up on two Windows 2016 Virtual Servers. Is there any documentation I can give our IT contractor for setting up these servers for running the HMI?
660
The latest version of Chrome (64.0.3282.137) on Android (7.0.0) doesn't seem to allow you to logout of the VTS Anywhere client (VTS version 11.2.10). We use to be able to tap our name and the menu would pop up and give you the option to Log Off. Is there a work around to get this working again or is this working in the latest version of VTS.
1 ...
