579
2.03k
30
107
pushpika1 posted Feb 20 '20 at 8:04 pm
Hi..
i`m using vtscada light version and i have Omron NJ series plc.when i trying to setting up plc with vtscada application,it shows only two series there.C/CV series and CS/CJ series.so NJ series not supporting with vtsada?if support, how to add drivers?which one i need to select while adding drivers ?omron fins driver or omron host link plc?please let me know.thank you.
321
I attached an excerpt from the help files, but I would like to discuss it for a second.
file:///C:/VTScada/VTSHelp/Content/D_Tools/Dev_Backups.htm
If there is a single application on site, and we need a backup solution that is automatic AND shutting down and restarting the application isn't possible, is using windows file history an acceptable method for continuous backup?
Has ther
5e4c9236a66ab
190
Carmelo posted Feb 4 '20 at 5:21 pm
It was not difficult to communicate a Koyo PLC with VTScada by means of Modbus TCP, being both, PLC and VTScada in the same LAN.
However, I have not been able to communicate them when the PLC is connected to a router outside the LAN of VTScada.
I typed a public IP address and the PLC port number when configured the TCP/IP port in the VTScada.
The resulting value of TCP/IP Port is -10,06
216
pieter posted Jan 31 '20 at 3:30 pm
For a school I work on three small PLC controlled processes supervised by separate VTScada applications to manage
some food processing equipment (evaporator, powder dryer machine, autoclave) that the students have to learn to work with.
Is there a report tool for VTScada that enables me to document the details of the tags of these applications in an organized way for the project document
recent by pieter  ·  Feb 14 '20 at 12:16 pm
195
jjauregui posted Feb 5 '20 at 12:20 am
I am looking to display the following VIC Client information in a project:
Server Name client is connected to
Client Name
Logged in Windows username that the client is running on
For item 1 (Server Name) I am using the following expression which is working fine: \DisplayManager\RootSession\Name
How would I reference items 2 & 3 above?
recent by Michael  ·  Feb 10 '20 at 3:27 pm
399
BFleck posted Feb 5 '20 at 7:04 pm
Getting error code 33,028 when trying to connect to Siemens S7 Driver. I'm using VTSCADA Light Version 12.0.04.
Any Help is Appreciated
Found Solution
Open the PLC project in the S7 TIA Portal software.
Go to Project View
In the Project Tree window, select the device that is causing the error.
Hit Alt-Enter to bring up the Properties dialog.
On the General tab,
203
Hi, I would like to put a numeric entry box somewhere in my application so that the alarm parameters (like low alarm setpoint) can be changed without the user having to go into the tag properties. Is it possible to reference these parameters outside the properties box? for example like how you can reference a tags value by using \Value
If that is not possible then is it possible to create a t
117
dbabler posted Jan 23 '20 at 1:24 pm
Has anyone experienced issues being online with an Allen Bradley PLC, causing VTScada to slow down or even lose communication at all? Doesn’t really cause any major issues (yet) but I’m curious if anyone else has seen this, thank you
recent by Michael  ·  Jan 23 '20 at 3:02 pm
255
CharlesH posted Jan 15 '20 at 6:17 pm
We are preparing to upgrade our software from 11.3 to 12.0+ and I am looking for any information that we need to know before upgrading? (i.e. are there any windows updates that don't play nice with VTScada v12?, any major changes we should prepare for going from 11.3 to 12?)
Also, as a secondary question, is it possible to launch our application on a different PC/Server and run it as if it we
150
Mrpike posted Jan 14 '20 at 4:34 am
What is the best/easiest way to manually disable comms to a device that is missing? I have devices that are offline at times and I want to optimize comms by preventing the driver from trying to constantly attempt comms to a device that I know is offline. Is there a setting I can toggle? Thanks.
142
dbabler posted Jan 9 '20 at 1:59 pm
We have 4 computers on the same network at a single location, none of them have internet access and the times on the computers will tend to float away from each other. Is there a way to sync all 4 using VTScada somehow? Basically just need to have one common time across all stations if possible.
155
Mrpike posted Dec 17 '19 at 3:10 am
Hi community, is there a way to clear the logged trend plot line data. I want to keep storage on the host pc to a minimum and do not want this file to get too large. Keeping data for a long time is not a priority so I would like to delete the logged data periodically. Thank you.
143
Mrpike posted Dec 21 '19 at 2:08 am
Hi community. I am trying to use a calculation tag to determine the bit status of an analog value. I cannot seem to get the syntax correct to put in the expression. I found the code snippet below but I think that may be for scripting not expressions...not sure Is there any documentation on functions and syntax for these expressions? trying [value] && 4 does not work to find the statu
5dfd7df070c36
recent by Mrpike  ·  Dec 21 '19 at 3:27 pm
244
9
Hello vt scada community. New user here. I am looking for assistance to create several digital tags based off the value of a single Modbus register. For example, register 40001 value =1 is "pump running". Same register 40001 value =2 is "pump stopped". How can I accomplish this with minimal tag usage? Thank you
recent by Mrpike  ·  Dec 19 '19 at 8:54 pm
278
I need to create a report that will display the lowest value that a tag registered throughout an entire day, along with the time that occurred. On top of that I need to display this information for the entire month.
I really do not know how to approach this at the moment.
I thought about using the standard report type since I believe it dumps all the available data into the report, and th
recent by drummin89  ·  Dec 19 '19 at 4:51 pm
222
CharlesH posted Nov 22 '19 at 4:48 pm
Is it possible to build a tag that can determine the elevation of my facility based upon the coordinantes in the parent site tag?
Or is it possible build a widget that references the Long. and Lat. of the parent site tag to determine site's elevation?
Thanks in advance!
