Answer - Yes!
Answer - Alarm notes can be found on the Alarm Page in the right-most column, it will contain an icon if the alarm contains a note. Simply click the icon to view the note. You will also see the note on the Operator Notes page. More on notes: www.trihedral.com/operator-notes
Answer - All application configuration, such as settings, tag configuration, pages and user accounts, are synchronized amongst all workstations that are running the application.
Answer - File types supported: .png, .jpg, .bmp, .wmf.
More on the Idea Studio: www.trihedral.com/graphic-editing-studio-new
Answer - A small portion of application settings require the app to be restarted when they are changed, though most do not. Compiling some types of custom code will require an app restart as well, though this does not apply to pages, graphics and tag types.
Answer - All configuration changes get synced to all workstations. These changes can be automatically deployed as soon as they are made, or it can be setup to require manual deployment.
Typically, the faceplate will need the number of tags associated directly with IO. Tags such as alarms, loggers, calculations, etc., are not part of the licensing tag count.
Answer - Yes, you will need one license per server. This can be a Runtime license or a Development Runtime license.
Note that free VTScadaLIGHT licenses can be redundant servers to one another but NOT to standard paid VTScada licenses.
More on VTScada redundancy can be found here: www.trihedral.com/redundancy-and-automatic-failover
Answer - Our input tags are capable of reading arrays of history from a PLC, so long as the driver supports it.
Answer - Yes. Pages can be parameterized so that their graphics can dynamically display values from different tags.
Answer - There are several ways to export data from the VTScada Historical Database.
From the Historical Data Viewer (HDV) you can export the visible values using the Export Wizard Button at the top of the HDV. See help: www.trihedral.com/help/Content/OP_HDV/OP_HDVExport.htm?Highlight=Export%20historical.
You can use the standard reports page to easily export data for specific tags and timef
Answer - Typically, all modifications to drivers are made directly by Trihedral personnel to ensure compatibility with future software releases. In exceptional circumstance, you should contact us directly.
Answer - VTScadaLIGHT can be installed as either 32 or 64 bit.
Answer - Yes, print alarm history using the icon at the top of the Alarm Page.
Answer - None of VTScada's features require scripts to work.
Our SupportPlus team regularly answers this question:
Q: I just updated to a newer version of VTScada and now my modems no longer work!
A: Customers using the modem dialer feature of the Alarm Notification System must ensure that they apply Windows updates on a regular basis. Updates to VTScada will often include modem drivers that have been patched to work with the latest Microsoft updat
jsanden
posted Apr 25 '17 at 5:18 pm
Does VTScadaLIGHT support the Anywhere Internet Client?
The mobile client seems to work fine in a browser, but when I log into the AIC throw a web browser all I see is a white page. A logon failed notification gets logged to the System Event DB even though I know I'm using the correct credentials.
A customer asked: Can operators be barred from shutting down a VTScada application?
Afternoon All;
I am trying to poll a Modbus flow meter. The register I am polling is a floating point, and at this time just looking to get a proper HEX response. Below is a couple of request and response. The request is correct as I have tested with a Mdbus master modbus simulator. It is looking to me that there is a inter-character time out issue. But any thoughts, questions or solutions wou
We appreciate the goodwill you bring to our software forum.
Our team of developers and programmers will be watching over things to ensure that posts are respectful and on-topic. To that end, here are some simple principals that we will be following.
This is a place for professionals to share information. Choose your language and tone accordingly.
Don’t make discussions personal.
Do
Is there a way to read a 32 bit modbus value directly into a 32 bit value in VTSCADA? This way we will not need to read a 32 bit value as 2 single 16 bit values and then combine it.
ChrisG
posted Mar 23 '17 at 7:42 pm
Are there any plans to allow tags names to be modified from the tag window instead of forcing us to browse for them?
This is a question that comes up more and more so our own Dave Spencer created this quick and easy video tutorial.
This video was created for VTScada version 11.2 in 2016-10.
https://www.youtube.com/edit?o=U&video_id=Ljc9DvsrHms
Instructions can also be found in the VTScada Help System.
https://www.trihedral.com/help/Content/D_DrawAndEdit/D_MultipleMonitors.htm?Highlight=multi%2
Is the latest version of VTscada, 11.2. Siemens S7 driver compatible with the S7-1200 and S7-1500 PLCs?
The driver list pdf on the website did not specifically list those models and I was curious.
Thanks,
JP
From a customer: Can multi-monitor layouts be configured separately for different users?
From a customer: How easy is it to find specific tag types when creating tags?
As of 2017-02-10, only the following tag types count against your license:
AnalogControl
AnalogInput
AnalogOutput
AnalogStatus
DigitalControl
DigitalInput
DigitalOutput
DigitalStatus
Pump
RateOfChangeTag
SelectorSwitch
StringIO
The licensed tag count is the sum of all licensed tags in running VTScada applications.
Have questions about your tag count? f
Is historical data logging enabled by default?
Question from a customer: I wanted to double check on this configuration for the type of application that the software will be placed into.
The City will have a VTScada installation at their WWTP, and the WTP. The sites are about 2 miles apart and will only be connected through the Internet. We were planning to have two separate applications installed at each site, but allow the WTP staff t
Question: I have a set of oil batteries, each of which has a standard set of values representing the pump and tank information. I would like to represent this information in a summary table with one row of data for each battery. We area adding new batteries on an ongoing bases and would like the table to be automatically updated with data from these new batteries.
