Dear Sir,
We plant to make Sequencer control for Governor and AVR system uses the PLC Simens S7 1200 PLC, can the latest VTScada communicated with this PLC?
I won't let me select alarms at event level. I want to monitor lagging poll times without bothering the operators.
ok the scada software where im at now is on windows server 2008. im trying to get it upgraded but finance is killing me. anyway my question is can I use the old tags in scada im using now and plug them into vtscada 90 day trial. can you plug and play kind of thing or do I need to go through and add all I/Os.
DanW
posted Oct 5 '19 at 4:00 pm
I've created a Numeric Keypad popup page (meant to be touchscreen friendly) and have created a GUIButton that when pressed is supposed to Close the Popup Window. I thought the Slay(Self()) should work but it seems to be ignored. It should be a simple thing but I've been stuck on this for a while now. I'll have to close the window after the user presses my "Enter" button as well. The "Close Page"
Dear All,
can we hide / show object base on user name login,
for example if the user login "Admin" object shown otherwise object hidden.
DanW
posted Sep 19 '19 at 1:36 am
We've been having a bit of a weird issue. Alarm Notifications are set to send email notifications on priority 1 alarms but every now and then an Alarm notification is sent for a priority 2 alarm and only a few specific priority 2 alarms it seems.
Is there a property that I'm missing that allows this under certain circumstances?
Thanks!
qué tipo de seguridad tiene vtscada
qué tipo de protocolo de comunicación
qué tipo de base de datos utiliza
gracias
Could you please assist me with an analog tag. I want to use the slider control to change the value of an analog input tag , this analog input tag is connected to a tank widget to give level indication.
I got it to work more than a year ago, but for some reason, it stopped working.
Im using a Click Koyo PLC and modbus addressing.The drivers are working as all the digital inputs responds.
jfrye
posted Sep 13 '19 at 7:00 pm
I am trying to calculate flow rate as a function of change of wet well level over time. I have tried using various tags types, adaptations of Ex 3-17 from the Adv Config Workbook, Intgr and Deriv functions; and everything comes up with some kind of errant data: Intgr gave max scale value, Deriv gave 0. Using the following provided the most realistic results:
"[PUMP_RUN] == 1 ? Latch(AbsTime(
So the system I’m currently working on is already providing me scaled data coming out of the flow computer. This is also in conjunction to the scaling of the raw data at the PLC level for my other analog instruments.
What is the best way to make sure I’m setting up my analog status tags properly so I’m getting the right historical data recording and displaying my data prope
jfrye
posted Sep 10 '19 at 8:51 pm
So my operators are asking that the trending be able to show the next couple of hours beyond the current time for predicting when certain cycles will be done. Is there a way to adjust the time scale/axis of the HDV to show future time, without data of course?
Is there a way to get shell execute to be OS dependant.
My ping button wont work in the android client.
DanW
posted Jun 7 '19 at 4:14 pm
We cannot seem to get Alarm notifications to work with Office365. The smpt server is supposed to be smtp.office365.com, I'm told, but when we have this as the SMPT address using port 587 and TLS encryption we get the following error: "SendMail Error [9]: Server doesn't support authentication"
We do get alarm notifications if SMPT settings as follows: Email Server: {company}-com.mail.protectio
jfrye
posted Aug 27 '19 at 5:03 pm
We are working on setting up HMIs (10 pack) for our local control panels; dual servers are setup with application, screens, and tags (designated with areas). We have looked at the tag area filtering literature, but are apparently lacking something on server/HMI architecture as we do not have all the options in "Workstation" and "Section" options in properties.
Is there a best practice for se
DanW
posted Jul 17 '19 at 9:33 pm
Hi, Is there a way to edit a Type property from the VT HMI? Some users will not have access to the Tag Browser but may be required to change IP address which is set up as a property of the Site Type. I tried several methods to set up a Linked Tag Widget but have been unsuccessful.
I'm thinking that I may have to script it somehow but want to know if I'm missing something before I go down that
Michael
posted Jun 17 '19 at 6:06 pm
Voice modem users,
Microsoft has broken TAPI with Windows 10 1903.
If you update workstations to this Windows version, you will struggle to get any voice functions from your voice modems, especially with the Multi-Tech USB modems.
DanW
posted Jun 21 '19 at 4:10 pm
How can I import a single custom widget that I've created and make it so that it is not editable?
Thanks in advance!
I am trying to integrate in a counter and some automated resets. The plant is currently changing the times of shifts a lot and I would like to allow them to configure on the fly. Is there a way I can change the trigger tag using parameterization? If so I cannot find any information on the exact syntax or how to do so.
What is the syntax for specifying a particular .wav file in the Alarm Setup tab of a Digital Status tag.
I want the sound for certain tags to be different from the others of the same Priority level. I'm planning on using an included .wav file.
Thanks
