382
1.18k
14
119
John_SBPG posted Apr 12 '19 at 3:49 pm
Here is my situation:
My current application has both my sewer lift stations and water towers in one application.
My water plant operators need to see only the water towers and hear alarms for them. But my sewer lift stations create an almost continuous stream of alarms. This had led them to mute the entire system.
Question:
Is there a simple way to turn of alarm sounds for my s
243
Viss posted Feb 21 '19 at 2:44 am
I'm new to VT Scada, Scada in general.
We are currently migrating off a older machine that is using a PCI Dialogic for a voice modem.
Our new machine only has PCI express slots so I'm looking for a replacement that fits the new machine whether it be PCIe or USB.
We only have 1 phone line strictly for alerts.
I saw that US Robotics and others like TP-Link list in there specs that they
recent by Viss  ·  Mar 29 '19 at 2:46 am
142
pdavitt posted Feb 21 '19 at 3:26 pm
I am trying find a gauge widget that will do the following.
Accept input from an Analog Status Tag that produces values from -100 to 100.
Has a zero centered dial which rotates to the left of center for negative values and to the right of center for positive values.
I originally thought this would be easy, but I can't figure out how to do it.
Any help would be appreciated,
Pat
335
Just downloaded the software and thought I had an easy project to start with. Took awhile to grasp the Tag hierarchy but think I have it.
My problem is this: Trying to setup VT to read from a Modbus TCP slave. I have tested the slave communication with a small Modbus TCP app, running on the same PC as the VT app and it works fine.
The ModBus TCP communication parameters are:
Slave I
89
clewis posted Feb 19 '19 at 5:08 pm
Is it possible to show an analog status tag in a gridlist cell? Would it display the alarms and engineering units?
In the titles parameter how would you Display Multi-line text
Do you have any examples?
recent by clewis  ·  Mar 1 '19 at 5:38 pm
117
Mel Nevergold posted Feb 20 '19 at 1:57 pm
I want a widget to drive to the site via long,lat that I can launch from the anywhere client.
I think this might help.
https://developers.google.com/maps/documentation/urls/guide
I've got an idea to try. BRB
gps
1.2k
9
RyanCaleb posted Nov 9 '17 at 1:31 pm
Hello everyone,
I'm a beginner with raspberry pi and also to Python language. I'm trying to use the raspberry pi 3 for industrial application and for that I've connected quite a few sensors (temperature, humidity, co2 etc.) I'm successfully able to get reading from the individual sensors and wrote a structured program with few functions related to each sensors to get reading from all the sens
247
I'd like to monitor, decode, and "interact" with a Modbus RTU device. Nothing complicated, I don't think. When I say interact the "linking" of meters/graphs to some of the registers etc would be really a nice to have and that seems to be inherent to your application.
Question:
Is VTscada Light the product I am looking for?
I reviewed the manual and looked at the software after insta
114
hank posted Jan 10 '19 at 7:50 pm
Hi Guys. I'm installing VTScada in place of another SCADA system and need a way to replicate the old watchdog functionality that they were using. Currently, their old SCADA system toggles a bit for each RTU, based on a set interval, and that bit is tied to a point in the RTU that will cause an alarm on site, if the bit stops toggling (loss of comms).
I believe I will need to do this using sc
147
Scenario:
Redundant server configuration (Primary + Backup)
Primary server online and working OK
Backup server ready but in standby mode (no coms/history..)
Several Operator Workstation on local network
The operators normally logged in Primary server
Then, primary server shuts down by any anomaly or forced event.
The question is how the Operator Workstations recover connection with Backup
64
This is a question I was asked by a customer recently:
Q – What is the easiest way to do a daily pump run report for 5 years?
A – The built-in Pump Activity Report should work. It provides you with activity over the entire time frame, not daily over x years. You'd have to run it for the previous day and then have (5*365) = 1825 previous periods. Not allowing for leap years.
678
9
jedwards70 posted Apr 23 '18 at 6:51 pm
Allen Bradley tag creation, if I create a tag for Bool in program, how do I set up address for tag? video is different than what I am seeing.
This is in Softlogix PLC simulator.
106
Single Application on 3 different Servers that are connected via radio link.
Call them ServerA, ServerB, ServerC
3 PLCs (actually more but this is good enough) each PLC is located in proximity to its similar server
Call them PLCA, PLCB, PLCC
Default configuration is ServerA - if primary does polling to PLCA, PLCB, PLCC. If ServerA goes down ServerB takes over all communication a
recent by Ralphf  ·  Oct 12 '18 at 9:02 pm
