188
1.27k
16
119
miahbrown posted Dec 16 '21 at 9:29 pm
I'm new to VTScada and currently using VTScada light and watching videos to get started. Two quick questions.
The text widget correctly reads a tag in the PLC but displays a ? at the end of the text. How do I get rid of the ? at the end of the text?
How can I change the color schemes for the gauge widgets? I'm using the Arc Meter gauge widget which is blue but don't see any
114
Ketul posted Dec 1 '21 at 9:39 am
I want to read data in VTscada individual tags from MS-SQL.
I have created database & tables in MS-SQL. I want to read some string, integer data in VTscada tags.
Also, I need to know SQL addressing to read data from MS-SQL in individual tags in VTScada.
Can you please guide me on this?
sql
249
Ketul posted Nov 17 '21 at 1:52 pm
I have a VTScada licence for 2 thin client configurations & I have configured one thin client-server setup for my application and I am able to log in with generated Anywhere URL, MIC URL & VIC URL from my windows10 machine.
I want to see my VTScada application on my mobile.
For that, I'm trying with MIC URL to browse in my mobile but the site is not opening.
Is any further co
144
hank posted Nov 10 '21 at 4:15 pm
Hi Guys,
We are working to implement the master / subordinate configuration for a system we're working on. The system has been running for a couple of years now, but we're starting to add some remote locations, each of which will have their own smaller VTScada license and server. We have done this before using Tag Area Filtering but the VTScada help now suggests using a master application wit
347
Good afternoon,
My name is Joseph Rhodes, I work as an electronic technician for the City of Tuscaloosa's wastewater treatment plant. The other day, our chemist sent me an email asking for data about the HCR Creek Flow. I was lucky that I have a co-worker who's about to retire point me in the right direction. I was able to find the data I needed for our chemist. I had to go through a few hoop
6167291b233d6
142
Joseph "JD" Rhodes posted Oct 13 '21 at 8:06 pm
I've been the City of Tuscaloosa's electronic technician for going on two years now. I've only ever used VTscada Anywhere Client to log into VTSCada. I've been having this issue with a missing minimize button on any and all windows I've open while logged into VTScada. This issue persists with all browsers and not just Google. I was able to slap a bandaid on the issue by switching over to accessin
61672e4e68201
447
Ketul posted Jul 20 '21 at 1:44 pm
I need to set the scheduling for the SOV's (solenoid operating valve) at a certain time interval.
attached an image for the scheduler?
I tried to make this with the Trigger tag available in VTScada. I have set On-time & Off-time of the scheduler. Scheduler starting at its set time interval. But how can I enable my tag for SOV at the same time?
I want to when my time started
60f6c484228e4
recent by Ketul  ·  Oct 12 '21 at 2:26 pm
88
glj077 posted Oct 3 '21 at 5:23 am
尊敬的先生:
我在使用addUser API函数添加用户时,发现不会执行,即无法添加用户。如何使用这个功能。谢谢你!
145
Ketul posted Sep 23 '21 at 2:31 pm
I need to integrate Google Map on VTScada instead of Openstreet map.
I have one of the Google map API-key with me.
I need to know what exact URL I need to enter to show Google Maps on the screen.
I have commented on all existing map sources & I have made one new slippy map tile starting from number 1 only.
Apart from URLs & API-Key, What other parameters do I need to change/m
59
YetiSB66c posted Sep 16 '21 at 7:20 pm
I would like to have 3 numeric fields on a popup page.
Display IO Tags Value
Display IO tags Scaled Max
3 Display IO tags Scaled Min
but i am unable to figure out how to access the Scaled Min and max properties of the IO tag.
i have tried creating tag widget and link the #ScaledMax, but that seems to have failed
118
Ketul posted Sep 13 '21 at 9:40 am
I want to link the Image to the tags as like widgets and I want to change image colors accordingly to tag values.
I have created one I/O calculation tag having a Digital type.
I want to take blowers images available from Images in Idea studio.
I want to link the IO calculation (digital) tag to this image and I want to change its color accordingly tag values same as like widgets
613f0e5a62503
132
Ketul posted May 20 '21 at 11:23 am
I have created context groups for Pump1, Pump2, Pump3...and so on in the tag browser.
My aim is to on idol studio screen Pump tiles is enabled/disabled accordingly context tags enable/disable.
e.g. If I have enabled context tags for pump1 & pump2 only then only 2 pump tiles widgets will be shown on the screen. Rest will disappear.
How can I achieve this ?
60a638885cb72
recent by Ketul  ·  Aug 30 '21 at 12:25 pm
50
I need enable/disable widgets based on selector switch mode.
ex. When I select auto mode in selector switch then all other pump control widgets (ON/OFF switch) needs to be disabled and when I put selector switch in Manual mode then I have access to control pumps ON/OFF switch.
How can I make it?
116
AC Salyers posted Aug 20 '21 at 3:32 am
Im trying to figure out how to embed text (Like an on call list) that is from a live document. I am currently using and Access Database that is pulling from an Excel spread sheet but I am using so many tags for every name and number it just doesnt make sense to do it this way. I think Im using somewhere around 20 tags just to have five people on the list and Im about to do this for a couple oth
1 ... 8910
