184
1.26k
16
53
jfrye posted Jun 28 '21 at 5:21 pm
I am trying to setup MDS Diagnostics Driver tags using TCP/IP ports, everything is on the same subnet, I have tried using the only ports I can find documented in the manual (GE MDS iNET) which are 30011 and 30010, but have no results. Have also tried the default 3001 and 502. Any suggestions? Thanks.
463
AC Salyers posted Apr 1 '21 at 8:20 pm
I use graphic editors quite a bit and some features that come in extremely handy that are absent VT Scada would make the work flow more seamless and less tedious in many cases especially when working with multilayer graphics.
• The first I would like to suggest is the ability to lock layers while editing pages or widgets so that they cannot be moved or changed while they are locked. To
183
hewkyle posted May 4 '21 at 3:35 pm
Good morning,
I am seeking additional resources, experience, or advice for integrating an Inovonics EN4080 IP gateway and associated equipment into VTLight.
Software:
VTLight
BQT BACnet quick test
Hardware:
EN4080 - vendor ID 1093
EN1235D
Network:
Locally connectivity between my laptop and the IP gateway.
Some examples of how the hardware should be structured in
recent by hewkyle  ·  May 20 '21 at 9:52 pm
80
I need to display a history statistics tag in the runtime &, when the operator clicks on it, open historical data viewer to open up & display that history statistics tag's source.
I was able to do this but what I came up with feels too clumsy.
I've created a group of display widgets with pop-ups disabled in the history statistic tag, with pop-ups enabled in the I/O & calculati
recent by Michael  ·  May 17 '21 at 5:33 pm
72
Brent Saunders posted May 11 '21 at 4:32 pm
We want to export and sync the VTScada tags to our dnp3 outstation database. We set up an odbc datasource and tested the connection with success. However when we hit "Export", we get "Operation Failed" at the bottom of the window. Any clues?
270
Ketul posted Mar 26 '20 at 12:53 pm
How can I make rotation in any shape.
For ex. I have draw one fan symbol in idea studio.
I want to rotate this shape in clockwise direction.
How can I do this in VTScada.
Please guide me through steps to rotate any shape in VTScada idea studio.
52
What's the best way to display a History Statistics (HistStats) tag to 3 decimal places?
I setup my HistStats tag to calculate a rolling avg from an instrument reading. It's doing what I need except It displays the results default to two decimal points & I need three.
When I bring up my HistStats tag's properties and go to the Display tab the only option there is a place to link to a
97
martin200261 posted May 5 '21 at 2:59 pm
The organisation I'm currently working for use measured data in offline models to produce predicted (forecast) data for the parameters we monitor.
Can VT Scada handle importing data with future timestamps? and can it handle multiple predicted data datasets?
78
martin200261 posted May 5 '21 at 2:55 pm
I’m hoping to integrate VTScada with one of the Azure data store products as the historic data archive, has anyone done this before?
My fallback position is to use MS SQL in Azure but would like to use Azure Data Lake or Azure Data Explorer
44
Ketul posted Apr 29 '21 at 6:32 am
I have created one context tag named it as "MRD455" and description as "MRD455 Testing". Then it displays its Description name on the sites overview main page by default.
How can I display the actual site name on sites overview main screen.
I want to see MRD455 (site name) on sites page. HOw can I do it.
608a44cad2bad
138
Basically i have a Total Volume Tag I want to snapshot it into Current Month and Previous Month Calculation Tags on the 1st of the month at 8am.
Volume = 1000
Snap = 500
Cmonth = Volume - Snap
At the rollover time move the Cmonth to the Pmonth
and then move the Volume into the Snap.
Does anyone have any good ideas in how to do this in VTScada?
Thanks,
recent by Kevin Way  ·  Apr 15 '21 at 5:38 pm
298
Ketul posted Apr 12 '21 at 11:40 am
I have created one IO calculation tag (analog) that shows the value of PUMP RUN TIME in the second.
Ex. Let say I got a tag value as 3600 seconds.
From this tag, I need to show PUMP RUN TIME as in format 01:00:00 (hour:minute:second).
If the value is 3720 I need to show it as 01:02:00 (h:m:s)
If the value is 3750 I need to show it as 01:02:30 (h:m:s)
How can I show that?
192
Ketul posted Apr 5 '21 at 12:07 pm
I have my DNP3 protocol XML file that includes Digital inputs, Digital outputs, Analog inputs, Analog outputs, Counters, etc.
I need to parse this data to VTScada and I need that VTscada generates tag accordingly.
How can I read the XML file into VTScada and end results that VTScada automatically generates the tags in Tag browser?
How can I do that?
1 ... 910
