615
1.91k
27
247
Each new version of VTScada introduces new tools and sometimes changes how older features work. Your VTScada license entitles you to upgrades for a period of time after purchase. (Maintaining a Support Plus contract provides unlimited upgrades.) You can find the end date of your paid upgrade period in the About dialog, accessible from the VTScada Application Manager.
Notes:
Please review
335
dougs posted May 31 '17 at 6:17 pm
Sync'ing the clock on a PLC with the VTSCada computer time comes up fairly often. Depending on the requirements of the PLC, there are a number of ways to do this. The easiest way for all of them require using a trigger tag in the VTScada application that will trigger at a known time. For now, call this TriggerTimeSync and set an On schedule for 01:01 am and off 2 seconds later with no off schedul
58
Tank cut-away images are designed to work with the Color Fill widget. Place a cut-away on a tank and then set the color of that cut-away to something that will be unique on the page. Orange is a great choice. Now, place a Color Fill widget on top of the cut-away and set its Changed Color to match the color of the cut-away.
The Color Fill will be visible only where it overlaps the matching co
127
Our SupportPlus team regularly answers this question:
Q: I just updated to a newer version of VTScada and now my modems no longer work!
A: Customers using the modem dialer feature of the Alarm Notification System must ensure that they apply Windows updates on a regular basis. Updates to VTScada will often include modem drivers that have been patched to work with the latest Microsoft updat
253
As of 2017-02-10, only the following tag types count against your license:
AnalogControl
AnalogInput
AnalogOutput
AnalogStatus
DigitalControl
DigitalInput
DigitalOutput
DigitalStatus
Pump
RateOfChangeTag
SelectorSwitch
StringIO
The licensed tag count is the sum of all licensed tags in running VTScada applications.
Have questions about your tag count? f
recent by dougs  ·  Mar 22 '17 at 6:10 pm
110
Question: I have a set of oil batteries, each of which has a standard set of values representing the pump and tank information. I would like to represent this information in a summary table with one row of data for each battery. We area adding new batteries on an ongoing bases and would like the table to be automatically updated with data from these new batteries.
359
Can one push data to REST APIs provided by cloud based machine learning/big data analytics platforms? Do you provide a REST API so one can push to your system. I am currently using http://infiniteautomation.com/ and combination of MEAN (MangoDB, Express, AngularJS, NodeJS based solution to capture low throughput data from battery operated devices on a mesh network.
122
Question submitted by a VTScada Certified Solution Provider
While discussing some remote access solutions, a question arose about how VTSCADA handles version differences. The specific example we were discussing dealt with an integrator remotely logging into a network and then making changes to an application hosted on a remote machine using the integrator laptop, and then pushing those chang
recent by BB001  ·  Mar 2 '17 at 12:17 am
248
The VTScada graphics library is located in VTScada\VTS\Bitmaps. The use of the term Bitmaps is a holdover from many years ago and no longer represents the actual makeup of the graphics library, which includes approximately 3000 WMF (vector), 1000 BMP (nonvector), 4600 PNG (nonvector) and 3000 SVG (vector). Some of these files are in more than one format. The development team noted this is because
131
Yesterday, a customer asked the best way to create a reusable set of bitwise reads for a packed PLC integer register. This is best done by creating a tag structure with a Context Tag as the parent. Create a parameter for the Context Tag called something like "BaseRegister" but leave it's value blank. Create the preferred Digital Status tags for each bitwise read as its children and set the Addres
