579
2.03k
30
203
In our project, we would like to use to connect VTScada to SAM (Sigma Air Manager - Air compressor management system) module with Ethernet IP communication.
In help guide, I don't find Ethernet IP communication details and not found driver also.
Could you please advise how to set up Ethernet IP communication in VTScada?
494
In one of our project, we want to move our VTScads project from one PC to another without losing all the data and validate license.
If I want to move, what are proper ways or suggested steps?
I know how to deactivate and activate license when we move from one PC to another. I would like to know about other steps that we need to take care of. Thanks.
200
Our SCADA is pulling analog I/O from a InSiteIG instrument for dissolved oxygen and total suspended solids. It is pulling modbus addresses; for example, register 30005 would be the sensor value for D.O. sensor 1. I am looking to improve on the basics of what has already been designed by using the I/O & Calculations, Analog (Calculation box ticked). I'm having somewhat of a difficult time in c
151
sparky posted Jul 13 '25 at 5:27 am
I have created small popup pages for controlling pumps and gate valves, etc. In the Application Configuration Display Properties, I have turned off all Title Bar and Task Bar decorations for popup pages. This works and looks as expected on the server, but in the thin client, all the decorations are present, seriously distorting the page appearance. Is there a way to turn them off in the thin clie
6873353059da7
recent by sparky  ·  Jul 16 '25 at 8:08 pm
115
Atomeg posted Jul 3 '25 at 4:13 pm
Hi! I have Omron CJ2H and I've trying connect VTScada to PLC Omron via Rockwell driver as Ethernet/IP protocol, but nothing worked. What am I doing wrong?
VTScada does not support connect to Omron PLC with eth/ip protocol?
I thought it doesnt matter what is the plc I have using, if that have this protocol. I try compactlogix, controllogix, etc. (symbolic adrr.), but nothings happened. Ple
recent by TomE  ·  Jul 15 '25 at 12:42 pm
111
Unter TwinCat 3 (Codesys) arbeiten wir mit OOP. Dabei nutzen wir unter anderem Methoden und Eigenschaften (auch Schnittstellen). Nun möchten wir die damit aufgebauten Bausteine über OPC UA nutzen. Dies funktioniert soweit, jdoch stellt sich die Frage, wie ich eine Methode unter VTScada auslösen kann? Wie müssen wir vorgehen, damit wir über die Visualisierung eine Methode
169
Ok, so I have a mqtt broker publishing to vt scada, and vt scada doesnt like it for some reason. It gives me a flat line for a graph every time the value updates in historical data viewer. It also seems to update values from all time to the most recent value given. For exampe, i have a current value with max min and average set at 26. Then mqtt publishes to vt scada the value of 25. All values th
687013a7051dd
132
I found facing error showing "Application Conversion Failure" error.
In help guide, it mentioned like this,
https://www.vtscada.com/help/Content/Dialogs/10607%20Application%20conversion.htm?Highlight=Application%20Conversion%20Failure
The selected application could not be converted to the current version of VTScada. The application will not be modified.
I don't understand clearly.
148
Hello.
I am trying to write 4 separate analog values to 4 separate 16 bit registers in a GE relay following a user hitting a button on a dashboard. It is to drive virtual inputs which will toggle a contact output. Wondering what the best way to do this is.
GE description of how to force virtual inputs:
For forcing Virtual Inputs, a message with 4 indivisible records must be written
686762b02057f
recent by justinhunt  ·  Jul 4 '25 at 7:50 am
52
Yaj posted Jul 2 '25 at 6:50 am
Could you tell me if VTScada can reliably monitor 250+ SNMP agents with 150 points per agent, and what are the key system resources or configurations that impact that performance?
84
Boonz posted Jun 25 '25 at 10:51 pm
So ripped this up to try to auto generate page menu's as a test.
is there no way to endcode the parameter into the MenuItemTag,
there is teh Decode of course but why is there no Encode?
Am i missing something?
Tried passing the Parameters multiple ways Unique, ParameterSet, root, name.
But it does seem to have no easy way to do this is it locked out for some reason?
119
nhig1369 posted Jun 17 '25 at 2:48 pm
Is there a way to access components of the PLC Alarm tag? I would like to create a widget for my ALMA blocks that show setpoints and have an analog bar showing the input value and alarm setpoints
recent by TriJim  ·  Jun 24 '25 at 9:37 pm
1234567 ... 29
