579
2.03k
30
174
cihat posted Aug 14 '24 at 7:37 pm
Hello, I am preparing a report, for this I want to bind it to a tag using the add parameter expresion to the duration value by selecting the time custom in the report tag, but it is said that I need to enter a value in the range 1-32767.
Can we make the I/O tag suitable for this. Obviously, I am creating the report time with the totalizer. I should somehow automatically assign this totalizer
recent by cihat  ·  Aug 23 '24 at 1:46 pm
122
j.schroeder posted Aug 22 '24 at 4:45 pm
I am looking to test the state change of some I/O tags, analog inputs for breaker status. Is there a way to force a value for the tag so I can see the Text Change and Color Box widgets change text and color?
recent by TomE  ·  Aug 23 '24 at 10:11 am
243
Atomeg posted Aug 12 '24 at 8:22 am
Hi!
Im trying to show popup window on internal tag change from false to true, but it doesnt work.. I write in source code this code (this code in Main [..]):
If [test_bool_tag]==true;
\DisplayManager\ShowPage("test_page");
Maybe I'm doing something wrong or other better ways to do this?
recent by TomE  ·  Aug 12 '24 at 1:51 pm
707
Has anyone connected VTScada MQTT client driver to AWS IoT Core MQTT broker successfully? I have a device publishing to a AWS and I can see the data coming in on the topic.
I added the TCP/IP port for the AWS broker. Really unclear as to what Name/Address to use, as well as the port and if I need to use TLS. I am thinking I do since the device I am using I had to copy the TLS Security certif
194
In the Bottom Left is a navigation widget made with Page Buttons. In the picture, the "Digster" page is opened.
My question is:
Is there a way to highlight the background of each button when the particular page is loaded on screen?
For example, in this cases, the "Digester" button is clicked and "Digester" button is opened. So the Page button should have a different background color.
6694d69167dfc
recent by Tames  ·  Jul 16 '24 at 3:50 pm
137
jbward8 posted Jul 11 '24 at 5:41 pm
I am trying to create a new tag that totalizes a tag based on month. (I dont want the last 30 days, but the total for January, February, etc.). The specific tag that I am using total pieces of production for a 12 hour shift. I need to totalize that tag to see the production for that month.
227
J_Hob posted Jun 7 '24 at 3:53 pm
Hi All,
Does anyone know if it is possible to move a current string tag value to another string tag?
I have tried to multi-write tag... it allows a constant to be written to a string output tag but not another string tag value to be written to a output tag...
Any help would be much appreciated.
493
Narciso posted Jun 27 '24 at 12:21 pm
Question: How to change the message that appears in the confirmation pop-up when the "Confirmation dialog" is enable in a button?
This is the default message:
"Are you sure you want to change the value to Running?"
This is what I would like it to say:
"Are you sure you want to issue this control action?"
What is the procedure to change the confirmation pop-up messa
667d4a66efc63
recent by Narciso  ·  Jun 28 '24 at 4:57 pm
106
gtuvar posted Jun 3 '24 at 11:57 am
Hi, I want to create custom DB to store some information. in the function call of DBSystem if I have defined 5 Number of Field attribute and stored few keys with DBAdd function. Now If I want one more field attribute and if I include that 6th field in DBSystem, will all the previous ID keys information be lost ? In my case Previous keys are lost. May you please suggest what can i do to take care
101
J_Hob posted May 17 '24 at 10:39 am
I have multiple recipes that are configured in my VTScada application. I would like these recipes to all start together with a common start request.
The two questions i have are...
Can a single bit start multiple recipes (Send values to PLC) ?
I understand a single bit can be the main source but the recipe start button needs to be linked directly to the recipe book.
Exam
1 ... 567891011 ... 29
