185
1.26k
16
297
9
Jason posted Oct 20 '22 at 8:28 pm
I have been tasked to make a standard VTScada template. This will get used in different applications. How it is supposed to function is that it will list all the shutdown conditions and it will display which ones are in fault (easy part). Then when you click on each shutdown it will take you to the faceplate of the device it is connected too. The problem I run into is when trying to have it all p
recent by Jason  ·  Oct 28 '22 at 7:15 pm
113
crd posted Oct 24 '22 at 10:35 pm
I am looking to get query data from a PostgreSQL database (not a VTScada database). Is there any way to do this in VTScada?
190
bbaer22 posted Oct 11 '22 at 9:01 pm
I would like to use a Text Change 2 state, and when it's in the 0 position or non energized state I want it to show one word in a certain color and in the 1 position I want a different word and color. It doesn't look like it would be tough, but I can't get it to accept a tag. I tried a bunch of different kinds of tags and it's just not accepting any of them. I would like to use a tag for this sin
recent by bbaer22  ·  Oct 14 '22 at 5:48 pm
113
jjanowiak posted Sep 6 '22 at 10:37 pm
I have a SCADA system that is not connected to the Internet, like most every SCADA system I work on. I have copied the Slippy Map Tiles for my area to my SCADA server. However, my map icons do not appear on the Map. No matter how far I zoom in or out.
How do I get my Map Icons to appear if I don't have an Internet connection?
151
Tames posted Jul 20 '22 at 6:47 pm
I have taken over a job and the previous creators used:
SState0Color
SState1Color
SState2Color
SState3Color
to pull in the colors form the style settings without pulling in the alarm color override. I have copied and pasted their code (from a working widget) and pasted it into my own but it does not work.
The code is:
\Root\Value == 0 ? SState0Color : ( \Roo
96
mike_yung posted Jul 20 '22 at 4:30 pm
This section of the help (linked to) tries to refer me to Microsoft for details on how to get a signed SLL certificate but the url which used to give that information now tries to upgrade me to Windows 11.
Please reply with the instructions for processing a reply to an SLL signing request & arrange for this to be added to your online help. Thank you.
https://www.vtscada.com/help/Con
173
Harley107 posted Jul 14 '22 at 1:33 pm
We currently run ge with primary, secondary, and a historian server.
What would be good specs to have server wise running the dual premium server setup 10-25k tags and 15 thin clients. Thanks for the input. Any brand you prefer over another?
340
Stefan_Neamtu posted Jun 21 '22 at 9:47 am
Hello, is there a way to create inside a page a drop-down menu containing links to specific pages ?
For example I would have a button named "Field Devices" and when i click on it - to show a drop-down list - Device 1 page , Device 2 page ... etc
616
VTScada stored all history data in its default Historian.
I have used that default historian only in my application and I have logged some values with the default Historian.
How Can I read this store's historian tag values in MS SQL Server?
I have installed the VTScada ODBC Driver and also add SQL Server Driver in User DSN on ODBC Administrator.
This SQL Server Driver I have conf
recent by Ketul  ·  Jun 10 '22 at 4:49 am
179
Ketul posted May 25 '22 at 5:29 am
I have secured my thin client link with the SSL X.509 certificate.
(I have made a new CSR request with my host+DNS name. I have validated the request from my CA & they send me the key and certificate. That I have to do Process Reply in SCADA and it successfully proceeded. I have added the SSLCertName property in my APPRoot file and restarted the application and ticked the SSL (443 port) op
628db0ac9d963
131
jjanowiak posted May 20 '22 at 11:09 pm
I want to create a custom Site Map Icon.
I would like to click the site icon on a map and have it take me to the related display for that site.
Here is what I have.
I have a Context tag. On the Display tab I entered the Lat and Longitude.
I entered the page name in "Custom Details Page".
When I click the Icon on the Site Map display, it opens my display as a pop up. I want it to
506
Ketul posted May 23 '22 at 12:33 pm
How can I import one machine history data to another machine. I want to copy all historical data of trends & reports onto another machine.
I have copied the Data folder of my application to my another application and replace the folder but I'm not getting Historial data inti it.
Is there any extra steps needs to perform here?
139
Hi ,
The contexte: I got a station (on site) and a control station (not on site). I want to know if is possible to revoke the control for the station to let the entire control to the control station. It will allowed the control station to change the I/o statues and do what they need to do and don`t let the station (on site) change the I/O statues.
Thanks for any help
1 ... 678910
