579
2.03k
30
693
8
We're familiar with most SCADA software, but still learning VTSCADA. We are used to the flexibility of script to do things that native symbols and widgets do not do.
Right now, we are trying to configure a button that when clicked, will perform:
TagA = TagB. (where TagA and TagB are Analog Values)
Searching through the help files, we can only find "button" style widgets in
recent by cardsfan  ·  Nov 19 '23 at 1:55 pm
174
I need to move history from one tag to another. For reasons, I need to remove one tag and replace it with another but I need to keep the history, and it's on about 80-100 tags.
Does anyone have a strategy for migrating data from one tag into another in bulk fashion? Exporting the data, massage the date and timestamp and do the CSV import would take much too long.
Thanks.
recent by Michael  ·  Nov 17 '23 at 5:52 pm
505
kurtisjackson posted Nov 14 '23 at 4:13 pm
I'm looking to see if there are any tools that can "skinny" down historical data. We are now supporting some hosts that had overly high poll rates when they were commissioned, the historian subsequently got bloated and is now using up too much HDD space.
Are there any tools available that can go back and remove swaths of data, or perhaps replace a 10 min span of 1 second data with a single a
recent by Michael  ·  Nov 17 '23 at 4:16 pm
105
I'm trying to add a new OPC UA client :
endpoint url : opc.tcp://10.247.10.2:4840
allow unsecured connections is on
authentification is Anonymous
inside the client certificate I created a new certificate
In the server certificate I saw an untrusted certificate and added it into the trusted ones
Now when I add this OPC UA client, the values says : 514 - Server Certificate subj
107
gtuvar posted Nov 11 '23 at 5:38 am
How to access a dictionary whose variable is created in one page as a network value in another page? e.g storedpumpdata is a network value variable and it is registered in X page. now I want to access storedpumpdata via dictionarycopy function in another page.
132
hienho posted Nov 9 '23 at 1:04 am
Hi everyone, How to get Value from SQL to VTScada. I tried to use SQL Query Driver but failed
654c2fed8f12d
154
saintatticus posted Oct 30 '23 at 3:50 pm
Hello, I have configured a Camera tag for my system but I would like to also configure an Alarm tag to alert the users if connectivity to that Camera URL is lost. Currently, if that connectivity is lost, the video stream just appears "frozen" in the dashboard no matter how much time passes -- i.e., showing the last displayed frame as a still image. But this is the same observed behavior if the
173
Tames posted Jul 20 '23 at 9:47 pm
I have tried searching in the help doc about this but I did not find anything.
I am trying to use a text box and have 1. inside of it, but it keeps erasing the period "." I am just trying to make a few text boxes to make it look like a list.
Example below
1.
2.
I tried using a f(x) and then using quotation marks, and it would work, but if I reopened the properties it automati
recent by Tames  ·  Oct 30 '23 at 2:33 pm
218
I have successfully received email alarm notification and sms alarm notification on my smartphone through Twilio with no additional Twilio configuration other than a Twilio phone number. Phone Calls are not being made.
I'm really hoping there is not additional programming to be made on the Twilio side.
Is there more programming than what was advertised to make call outs work, or should c
194
Currently we have a SCADA system working, but we want to change the IP of the devices in site (Modbus Compatible Device). When we do that, we will have to do port forwarding in the router. Instead of that, is there any way in VTScada to associate the IP Address of the device? in this way, when we change in site the IP Address, we only have to change the value in the SCADA directly inst
653a5cae0bec3
128
I am trying to grant consent for OAUTH 2.0 for VTScada to use an MS365 email account to send and receive. When I click on "Consent" in the Review and Modify Security Settings window, the dialog "Obtain Consent for Grant" opens and just says "Operation Status: Consent Operation Running" but nothing else happens.
No browser window opens as mentioned in
https://www.vtscada.com/help/Content/D
159
jroc11 posted Oct 5 '23 at 3:24 pm
I currently have a kepware tag that is outputting pulses. Each pulse is equivalent to 100 cubic feet. This tag doesnt reset so its constantly going up. Im trying to figure out an accurate way to track these pulses in intervals of hour, day, week, month, year. I started with hour and tried using a history analytics tag which would only show the amount of pulses in the past hour rather than startin
recent by cardsfan  ·  Oct 15 '23 at 3:40 pm
225
I have a number of widgets which need to reuse in another application.
These widgets contain text objects which are lost somewhere during the import/export process. If it matters, some of those text objects display linked tag properties & others display the results of expressions.
Is this a bug that's still being worked on or is this normal documented behaviour which is causing me is
recent by mike_yung  ·  Oct 4 '23 at 5:50 pm
143
We're a system integrator and have created custom types which we wish to reuse in many of our VTScada customer applications.
We currently have a multi layered app, with an OEM layer that's pretty much empty & a customer application layer which contains all the types, tags & pages.
How can I move the custom types from the customer application layer to the OEM layer so these types c
113
H2OTom posted Sep 25 '23 at 12:55 pm
Is there a way to require an operator notebook entry when setting a value?
I have a bit that is used to bypass a process timer and would like to force the operator to enter a note when they use this. Currently I have an I/O and Calculations tag setup as a Digital[Out] and I'm using the Toggle Button to write a 1 to the bit when pressed.
I'm hoping to have it setup so when the operator p
231
benjaminh posted Sep 15 '23 at 9:02 pm
I'm trying to use an Analog Summary report as an easy way to generate spreadsheets with min/max/avg/total measured hourly flow quantities for a user defined period. The analog summary report is tied to a tag that is written to once per hour with the calculated flow total for that hour.
The average/min/max values are correct and have been verified by comparing them to the "Raw Data" in the HD
255
We are building up a new application to replace an older SCADA system. We don't want both systems polling the end devices so VT's port tags are all disabled until we are ready to commission.
However, the modbus devices are still getting polled somehow. We see poll failures where there should be zero activity. When failing over to the backup server, we saw tens of thousands of polls attempte
1 ... 891011121314 ... 29
