578
2.03k
30
173
Hi, I'm working in an application for control some devices using a PLC GE RXi3,for that, I' m using a Selector Switch widget and the same tag type. Now, I would like write in two different addresses (%MXXXX and %MYYYY) at the same time when I select and specific selector switch position. I try using this simple expression "%M01542 && %M01543" is accepted like good but go to error when exe
221
Popup pages can appear because of a button click, but is there a way to get a popup to appear based on a set of conditions? The way you get the access denied popup if you haven't logged in. I want to prompt users to correct the action that has prevented an action if possible. Is there something possible that is different than the alarm popup bage, thats more simliar to the login prompt? Would
6447d2f2838e4
recent by abarnesTEI  ·  May 1 '23 at 1:35 pm
2.5k
Hi, is there a recommended way to trigger on-screen keyboard on Windows 10?
I have an application with a Program Spawn button and a path to c:\Windows\System32\osk.exe
The same button on Windows 7 would open the on-screen keyboard but not on Windows 10.
However, if I change it to notepad c:\Windows\System32\notepad.exe, it would work on both Windows 7 and Windows 10.
Thanks
Vic
recent by admin  ·  Apr 27 '23 at 7:32 pm
100
Is it possible to make the droplist widget write to a property of a context tag? I haven't been able to successfully change the properties this way of a Context tag this way. I can always set up a hotbox an operator can right click and edit properties in this way. But the most user friendly/ optimal method for data governance would be this droplist widget.
Another way would be to create
873
12
Brandon Peay @ Fritz Winter posted Jun 21 '19 at 4:26 pm
I am working with a Siemens S7 TIA Portal program and I am trying to pull the part type from the PLC into the VTSCADA system. The issue I am having with the String I\O is I am only getting the DEC form of the tag and not the CHARACTER values. In the PLC in a watch table when I look at the exact tag in DEC I get the value of 2565 but in CHAR I get DB 10 (FW part type). is there something I can do
recent by mike_yung  ·  Mar 23 '23 at 2:59 pm
60
Jason posted Mar 13 '23 at 3:25 pm
Looking to add the time in the top right comer of the title bar for a popup page, I know a command to display time but how can I get it to show in the same spot on the right hand side? The page title right now is dependant on the tagname thats used for the popup
78
flagshang posted Feb 27 '23 at 2:38 am
I have only one VTScada. I want to regular move the earliest month history data to another disk driver for efficiency and data backup. How can VTScada do this? Thank you.
75
Please provide an example of how *this is done.
May be set in a parent context tag if you have Modbus devices with differing address offsets.
I have no idea how to put a context tag into an application's configuration.
... * referring to latest help
248
This help page describes thin client licensing as follows.
If you have a multi-server application and want to allow connections to more than just one server, each must be licensed to allow client connections.
It is common for one of your server keys to allow many thin client connections and the others to have few or none.
162
Hey guys,
We have a decently large application (80k tags) with lots of Flow Computers. We have Low Flow setpoints and Debounce timers settable by operations and just go the Alarm tab on each Analog Status (FC still uses old style tags).
One issue we've noticed is if you change the parent tag type, or have a hard shutdown due to server issues, all these values get wiped out and get set to
recent by tmills10  ·  Feb 21 '23 at 9:23 pm
87
I would like to use the selector switch tag type as it has built in feedback alarms and the switch widgets. However, the components I am using will pulse the command to its state. Another reading will verify that the command worked and that the component is in the commanded state. I don't see an option to pulse the output of the selector switch. Will I have to use the digital IO tag and a cou
94
I tried to setup Thin Client access to the VAM according to the online help but got stuck at this step.
' 7. Create a user account and grant it the VTScada Thin Client privilege.
I couldn't find a "Thin Client privilege" to add to my account but adding "Internet Client Access" seems to work.
If I've done something wrong please let me know what I need to do to access the VTScada Thi
222
Parent Child References are the easiest to map. However, I am exploring the possibility that the hierarchy for an application might require references to properties in an adjacent tag in the hierarchy. I haven't run into issues when concatenating descriptions in this way. However, in other values that require a specific data type (Scan Intervals, Drivers, AIO Scale Min's and Max's), I have exp
172
Jason posted Feb 13 '23 at 7:59 pm
Would anyone happen to know a way I could have a button do 2 different things on a single press? Like set values to 2 different tags or set a value and change screens?
recent by Jason  ·  Feb 14 '23 at 6:51 pm
63
steven posted Feb 9 '23 at 7:14 am
i haw installed VTscada 12.1.12 and trying to add a OPC UA Client driver in my tag Browser. but when i selecting this type, the program closes.
is the VTScada light supporting OPC UA Client Driver?
154
mike_yung posted Feb 3 '23 at 2:25 pm
Has anyone found a way to print a full help topic from VTScada's online help? The only workaround I could find is selecting all the text, then copy pasting. If anyone's got something better I'd be excited to learn from you.
https://www.vtscada.com/help/ is not the only website with this issue.
It seems like it's a common problem with sites which haven't been upgraded to remain compatib
recent by mike_yung  ·  Feb 8 '23 at 4:11 pm
