578
2.03k
30
62
hienho posted Jul 19 '23 at 8:42 am
how can i create a table to read data directly in vtscada
64b793d40c3d6
93
Mel Nevergold posted Jul 15 '23 at 1:52 am
So, we have three auto flame mini Ml8 controllers and a Trane Tracer MP503.
From my understanding the Tracer only does LonTalk and the auto Flame units are rs485 modbus.
It looks like we'll have to rely on the modbus connection as there isn't a LonTalk Driver.
Any recommendations?
164
rarmour posted Jul 13 '23 at 10:55 pm
We have a 25K Dual Server Premium bundle. Application is in early development. Our industrial control network is not allowed to touch our corporate network or the Internet by policy. The only exception is a data diode between the control and corporate network.
We would like to have a runtime server that anyone on our corporate network can access in a "read only" fashion. It appears the tw
197
When I run VTScadaODBCDriverInstall.exe the install completes almost immediately, so quickly I don't even have time to click on the "Show Details" button to see what's going on.
Is there a command line option that will allow me to enable logging of the install activity to a text file?
The 3rd party software which needs this driver doesn't detect it as installed & reinstalling our dr
5k
Updated January 30, 2026
VTScada should work with any standard voice or SMS modem. Though we cannot guarantee the compatibility of third-party modems across all Windows operating systems, our team has provided the following comments on modems that we have used by us or our customers. We have no relationship with these manufacturers.
Fewer and fewer manufacturers are offering physical mode
recent by admin  ·  Jun 9 '23 at 8:40 pm
364
I've been using VTScada for a few weeks now and would like to check if you can recommend ways to implement sequences of events that may have different order, and time delays between them.
For example, let's say I want to have a button X that when pushed activates Sequences 1 and 2 as follows:
Sequence 1:
If option A preferred (this implies option A is active):
Write 1
100
lsmith posted May 25 '23 at 4:28 pm
I have a popup menu that calls other popup pages, and I want the menu to close after I use it to open a page. Here's my code below. When I open a popup, however, my code closes the menu along with the popup I just opened. Why? How do I fix this?
If \DisplayManager.CurrPage() != Self(); {Lose focus}
\DisplayManager.StopPage(Self) { Close window };
148
I need an expression to read application properties.
I found something in the help describing how to "Use Application Properties" in an expression however it's actually describing how to use system properties in an expression.
https://www.vtscada.com/help/Content/Scripting/Expressions/UseAppProperties.htm
When tried to use ...
\Code.PropertyName
... it did not work when my prope
recent by mike_yung  ·  May 19 '23 at 2:56 pm
67
klausm3@gmail.com posted May 12 '23 at 12:35 pm
I am looking into replacing the scada system we have with VTscada but have run into a problem . Some of the addresses on the Omron plc (Modbus) are strings and contain ascii text which needs to be manipulated via the scada Ie Product name. At this stage the tag returns a number not text. Can anyone help me with this.
194
abTimJ posted May 10 '23 at 7:21 pm
I've created some tag types and instances of them, but when my project loads, I get a "Tag name collision" in the Error Report.
I've checked the help files and it mentions that the duplicate tag will be disabled, but both tags in the tag browser are enabled, and further to that, the names of the tags and the unique IDs are all different. The only thing that is the same is the "declaration key
recent by abTimJ  ·  May 10 '23 at 9:08 pm
