sparky
posted May 12 at 5:30 pm
I am looking for a way to for a user to logoff one workstation when they login to another. I am getting push back on login times being too short and the powers that be insisting on long times (4 hours or more) before they are automatically logged off. However, I've discovered that they are now either sharing one individual's login, or that person is logging in everywhere and leaving.
Either
Zackbo
posted May 1 at 4:51 pm
What would cause all the VIC's time to be one hour behind? Both the server and the client PC time is correct.
VTScada alarm notifications and are now getting SendMail Error [9]: Server does not support AUTH when sending through smtp.gmail.com.
Setup:
VTScada latest version, Windows 10
SMTP server: smtp.gmail.com, port 587
Transport layer security: "Use TLS if available"
Gmail has 2-Step Verification on, using app password
POP3 incoming side works fine with the same credentials
What
Martin
posted Apr 9 at 4:49 pm
I am creating a project to track production of equipment for multiple customers at one shop. I am using parameterized pages.
This includes a Level 1 Page for Customer Selection, Level 2 page for Equipment Selection, and Level 3 that includes a widget (String entry for Equipment ID, and Droplist for Process Status for that piece of equipment). I have also setup a Dashboard Page to see all Leve
Hello, I'm having a problem!
I created a username and password for my project in VTScada, but I wasn't careful and must have made a mistake, and now I simply can't access anything!!!
Can you help me reset my login and password so I don't have to redo my entire project?
Thank you in advance to everyone who is interested in helping!
Zackbo
posted Apr 3 at 3:05 pm
I have a 4-monitor system with 4 separate VIC sessions running. Is there a way to configure the parameters of a VIC session shortcut to display in a specific monitor?
Thanks!
Gsrosa
posted Mar 23 at 5:03 pm
I'm trying to create a template to use on a report but its somewhat complex.
I want to know if there's a way to make something like that on VTScada Light without the ODBC or Excel Add-in.
I would like some help from you. I need to export an analog tag to an Excel (xls) report, but when I export it via the report, the tag exports the decimal places using periods (.). I need it to export with colons (,). Is it possible to make this change? Thank you.
Are networked SMS appliances going to be supported in the future?
Similar to the development of the USB voice modems to the VOIP modems.
I've looked and tested and seem to be missing what seems to be a simple concept. I'm also trying to stay away from scripting, even though I know I've found examples of doing what I need there.
I'd like to have a tag, using expressions or a special tag that I might have missed, to update based on another tag getting its value updated. I've used a trigger tag and have gotten close, but I seem
beno
posted Jan 7 at 5:59 pm
Brand new to VTSCADA but not SCADA platforms.... (I plan to sign up for either remote or in-person training ASAP).
I have a noisy alarm and rather than just bump the setpoint, I'd like to understand what the tag is reporting.
Here are the tag details as exported from the Record Details pop up box.
Name Rockwell\Alarms\CommsLoss
Description PLC Loss of Comms
hilldc
posted Mar 8 at 2:43 pm
I'm getting about an hour flatline on trends which started with the time change this morning. I have checked times on all servers to make sure they updated and match. Any suggestions? Thanks
At our treatment plant we have 5 Schneider Electric Trio JR Radios. We recently had an issue with communications, but got the issue resolved. I am wanting to implement a few things on VTScada to give our operators a graphic should there ever be any kind of problems with a drop of plant wide communications. My only concern is that I do not have much experience when setting up or configuring the SN
I am testing Driver Multiplexer with two Kepware OPC UA servers.
Q1> When failover switching to secondary driver successfully, data updates can see in values.
But the issue is
Historian logging still considers to log or not depending on deadband value of another driver IO tag. I noticed this when I found the data is not updated in historian. How should i fix it? I want to get new
I am currently involved in deployment a distributed system, with a highly restrictive radio link which I am not allowed to send VTScada data across.
Modbus communications are in place for this project.
So I have:
CentralVT and CentralPLC at the central office. CentralVT talks only to CentralPLC, which servers as a data concentrator for all remote sites.
Site1VT and Site1PLC. Site1
I've upgraded to 12.2 & need the VTScada compiled HTML help files (VTScada_12_2.chm) for use with Notepad++. Can this be made available for download?
Does anyone know if Trihedral has, or plans on producing a momentary switch that actually looks like a toggle switch instead of a plain button?
We know about the momentary button and it functions the way it is supposed to function, but for aesthetic continuity we would like to have a toggle switch that is momentary.
Hi, i’m looking to purchase a surface laptop 7. Looks like it runs snapdragon ARMs. Does anyone know if SCADA light will work with this computer? Thanks!
Jerry
posted Feb 10 at 1:34 pm
Some models of the Omron NJ series PLC support OPC UA Server.
However, the PLC we are currently dealing with does not support OPC UA Server.
May I ask if VTScada has other ways to communicate with this PLC?
The NJ PLC is not mentioned in the driver list.
Thank you
Hello.
Is it possible to use VTScada as a PLC-to-PLC gateway,
allowing two or more PLC's to communicate with each other? If so, how can this be configured?
Thank you
Good morning,
I currently work from an established VTS application that is our treatment plant and liftstations application. I've created a "training environment application" within VAM. I was wanting to export a created tag type, but during export to "training environment" I got a failed message mentioning that it failed due to GUID differences between the original application and training
rishik
posted Jan 27 at 5:18 am
I downloaded VTSCADA light to create a usecase demo for about 50 tags in one shed. However, after downloading the application and on opening it - I am unable to see any options for accessing the Application Manager.
How do I access the application manager in VTSCADA Light?
Are there specific tutorials/documentation to navigate the Light version?
Hi friends,
I was requested to upgrade our system. i was coming with a plan, to upgrade the remote computers first before the main pc servers.
is there anything i should be aware, or a link where I can follow the steps, and best practices ?
Thanks!
I have been searching high and low for a resolution for the easiest way to copy one widget/group from one screen and pasting it into a different screen in the same exact coordinates. What am I missing here? I know I can go in and edit the coordinates once I paste it, but there just HAS to be an easier way. Please help a noobie.
Boonz
posted Jan 19 at 2:33 am
Now these are some handy tools for the old L, B, R,T coordinates .
Have a new issue where most people with iPhone's cannot load a Anywhere URL. It works on all desktops and Android devices however most times when on iPhone it will not load.
VTScada was upgraded to latest version, same issue. Can't seem to find any discussions of others reporting this. Just looking to see if anywhere here has seen this.
The server logs this Windows Event when it happens.
Maiza
posted Jan 15 at 2:16 pm
Como faço para configurar o botão "relatórios" para gerar automaticamente um relatório pelo HDV, sem precisar acessar a página de Relatórios? Estou com dificuldades.
Como faço para configurar este botão (com as tags que precisam ser exportadas) para que eu possa simplesmente clicar nele?
The report tag has its "email settings" where you can manually add or remove recipients of that report.
I'd like to offer more of a self-serve option where someone can enter their email on a page/popup which would then inject an updated recipient list into the report tag or script.
Parameters or expressions aren't allowed in this field and I have yet to figure out how to push a variable
When trying to setup communications to import tags I am getting an error of "Driver Not Ready".
Also, when I try to set up tags individually, the application is unable to read from the PLC to choose the appropriate I/O.
I have noticed that I am not getting a value next to my driver, but I am getting a zero next to my port. I cannot find a reason for a value bein
Looks like VTSCADA’s OPC server functionality exposes tag values and some properties, but no alarm info or acknowledgement ability.
Is external OPC alarming and acknowledgement only doable with script trickery or “PLC Alarm” tags?
